I Integral-form change of variable in differential equation
Jaime_mc2
I have the following differential equation, which is the general Sturm-Liouville problem,
\dfrac{d}{dx} \left[ p(x) \dfrac{d\varphi}{dx} \right] + \left[ \lambda w(x) - q(x) \right] \varphi(x) = 0\ ,
and I want to perform the change of variable
x \rightarrow y = \int_a^x \sqrt{\lambda \dfrac{w(t)}{p(t)}}\, dt\ .
I used the fundamental theorem of calculus to get
\dfrac{dy}{dx} = \sqrt{\lambda\dfrac{w(x)}{p(x)}}\ ,
and get the differentiation operator with respect to the new variable as
\dfrac{d}{dx} = \dfrac{dy}{dx}\dfrac{d}{dy} = \sqrt{\lambda\dfrac{w(x)}{p(x)}} \dfrac{d}{dy}\ .
My question is about how do I get the differential equation to be expressed in terms of ##y##. My first thought was realising that ##\varphi(x)## could just be expressed as ##\varphi(y)## if there exists an inversion such that ##x = x(y)##. Then I just extended this idea to ##w##, ##p## and ##q##, and I arrived to the equation
\dfrac{d}{dy} \left[ \sqrt{w(y)p(y)} \dfrac{d\varphi}{dy} \right] + \left[ \sqrt{w(y)p(y)} - \dfrac{q(y)}{\lambda} \sqrt{\dfrac{p(y)}{w(y)}} \right] \varphi(y) = 0\ .
Is this approach correct?
I observe if you choose w as w=q, the equation becomes easy enough to solve.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
