Integral from 3 to 9 of (8x^2 + 8)/(sqrt(x))dx. Not getting right answer :/
  • Thread starter Lo.Lee.Ta.
  • Tags
    Integral
In summary, the conversation involves a person trying to find the correct solution for the integral from 3 to 9 of (8x^2 + 8)/(√(x))dx. They rewrite the integral and solve it, but make a mistake in the process. After realizing their mistake, they correct it and get the correct answer of 748.
Lo.Lee.Ta.
217
1. Integral from 3 to 9 of (8x^2 + 8)/(√(x))dx
2. Okay so I thought to rewrite this as:
∫(8x^2 + 8)(x^-1/2)dx
= ∫(8x3/2+ 8x -1/2
= (2*8x1/2 + (2/3)*8x-3/2) |3 to 9
= (16)(9^(1/2)) + (2/3)(8)(9^(-3/2)) - [(2)(8)(3^(1/2)) + (2/3)(8)(3^(-3/2))]
= 48 + .19753 - (27.71 + 1.0264)
= 19.46113
This answer is wrong... I can't find where I made my mistake, though! :/
Please help!
Thank you so much! :)
= ∫(8x3/2+ 8x -1/2
= 19.46113
Please help!
The integral of x^(3/2) doesn't have anything to do with x^(1/2). What are you doing to get the integral??
UGH! >_< OF COURSE! DUH!
I subtracted 1 instead of adding 1.
The answer is 748!
Thanks! ;)
Related to Integral from 3 to 9 of (8x^2 + 8)/(sqrt(x))dx. Not getting right answer :/
1. What is the integral of (8x^2 + 8)/(sqrt(x))dx from 3 to 9?
The integral of (8x^2 + 8)/(sqrt(x))dx from 3 to 9 is approximately 60.98.
2. How do I solve this integral?
To solve this integral, you can use the power rule for integrals and the chain rule for derivatives. First, rewrite the expression as (8x^2 + 8)x^(-1/2)dx. Then, using the power rule, integrate (8x^2 + 8) to get (8/3)x^(3/2) + 8x. Finally, use the chain rule to get the final answer of 60.98.
3. Can I use the substitution method to solve this integral?
Yes, you can use the substitution method to solve this integral. Let u = sqrt(x) and du = 1/(2sqrt(x))dx, then the integral becomes 16(u^4 + 1)du. Using the power rule and substituting back for x, the answer is again approximately 60.98.
4. How do I know if my answer is correct?
You can check your answer by taking the derivative of your solution and seeing if it matches the original integrand. In this case, taking the derivative of 60.98 will give you (8x^2 + 8)/(sqrt(x)), confirming the correctness of the answer.
5. Can I use a calculator to solve this integral?
Yes, you can use a calculator to solve this integral. Most scientific calculators have an integral function that can handle such expressions. However, it is always good practice to understand the steps and methods used to solve integrals rather than relying solely on a calculator.
