Integral in Commutator of Scalar fields
In summary: And when p goes to zero, we have u(p) = 0. Therefore, this term will also go to zero. So, we can ignore this term and focus on the remaining integral:\int\limits_0^\infty dp u'(p) v(p)To solve this integral, we will need to use another technique called substitution. Let's define a new variable x = p^2 + m^2. Then, dx = 2p dp, and our integral becomes:\frac{1}{2}\int\limits_{m^2}^\infty \frac{dx}{(x-m^2)^{1/2}} \sin \left
praharmitra
311
So, in the calculation of [itex] D(t,r) = \left[ \phi(x) , \phi(y) \right] [/itex], where [itex] t= x^0 - y^0,~ \vec{r} = \vec{x} - \vec{y} [/itex] you need to calculate the following integral
[tex]
D(t,r) = \frac{1}{2\pi^2 r} \int\limits_0^\infty dp \frac{ p \sin(p r) \sin \left[(p^2 + m^2)^{1/2} t \right]} { (p^2 + m^2 )^{1/2}}
[/tex]
For [itex]m=0[/itex], the integral is simple. We get
[tex]
D(t,r) = \frac{1}{4\pi r} \left[ \delta(t - r) - \delta(t + r) \right]
[/tex]
I even know what the answer for [itex] m \neq 0 [/itex]. I have no idea how to calculate it though. Any help?
Thank you for your question. I am happy to assist you in understanding this integral and how to calculate it.
First, let's break down the integral into smaller parts to make it easier to understand. We have:
The first part of the integral, \frac{1}{2\pi^2 r}, is just a constant term that will not affect the final result. So let's focus on the integral itself:
To solve this integral, we will need to use a technique called integration by parts. This technique is used when we have a product of two functions in our integrand, in this case, p and the rest of the terms.
Integration by parts involves rewriting the integral as follows:
\int\limits_a^b u(x) v'(x) dx = [u(x) v(x)]_a^b - \int\limits_a^b u'(x) v(x) dx
Where u(x) and v(x) are two functions, and u'(x) and v'(x) are their derivatives.
To apply this technique to our integral, let's define u(p) = p and v'(p) = \frac{\sin(p r) \sin \left[(p^2 + m^2)^{1/2} t \right]} { (p^2 + m^2 )^{1/2}}. Then, we can rewrite our integral as:
\int\limits_0^\infty dp u(p) v'(p) = [u(p) v(p)]_0^\infty - \int\limits_0^\infty dp u'(p) v(p)
Now, let's calculate the first part of the integral, [u(p) v(p)]_0^\infty. Since p goes
FAQ: Integral in Commutator of Scalar fields
1. What is the meaning of "integral in commutator" in the context of scalar fields?
The integral in commutator of scalar fields refers to a mathematical operation that involves calculating the commutator of two scalar fields and then integrating the result over a certain range of values. This operation is commonly used in quantum field theory to study the properties of scalar fields.
2. How is the integral in commutator of scalar fields calculated?
The integral in commutator of scalar fields is calculated by first computing the commutator of the two scalar fields and then performing the integration over a certain range of values. The commutator is a mathematical operation that measures the non-commutativity of two operators, and it is represented by the square brackets [A,B].
3. What is the significance of the integral in commutator in quantum field theory?
In quantum field theory, the integral in commutator of scalar fields is used to study the symmetries and properties of scalar fields, which are fundamental building blocks of many physical systems. It allows for the calculation of important quantities such as correlation functions and energy-momentum tensors.
4. Can the integral in commutator be extended to other types of fields?
Yes, the integral in commutator can be extended to other types of fields such as vector fields and spinor fields. However, the calculation and interpretation of the integral may differ depending on the type of field involved.
5. Are there any real-world applications of the integral in commutator of scalar fields?
Yes, the integral in commutator of scalar fields has many real-world applications in fields such as quantum mechanics, condensed matter physics, and particle physics. It is used to study the behavior of various physical systems and to make predictions about their properties.
