Calculating Time to Reach 100,000 Trillion Meters in Hubble Flow | PF Forum
In summary, the conversation discusses the concept of the net energy of the universe being zero and the expansion of the universe. The Hubble flow and its relationship to the speed of light and distance are mentioned, with calculations being made to determine the time it would take to reach certain distances. The conversation also touches on the issue of energy conservation and how redshift can serve as a yardstick for measuring distance in the distant universe. There are disagreements about the assumptions being made and the accuracy of the calculations. Additionally, there is a mention of the idea of galaxies moving away from us at the speed of light.
Stephanus
1,316
104
Dear PF Forum,
While learning why the net energy of the universe is zero. I've been reading about the expansion of the universe, and of course in it, Hubble Flow.
https://en.wikipedia.org/wiki/Hubble's_law = 73km/s per Mega parsec
https://en.wikipedia.org/wiki/Parsec = 3.26 light year.
In the end I come up with this number.
Hubble flow is 2.37E-18 m/s per meter. Of course as often said, it only works in space where there's very little gravity. Not here on Earth or in interstellar medium, perhaps in intergalactic space?
Let's say H = 2.37E-18 m/s per meter or H = 2.37E-18/t.
Now the next question is, how long does it take to reach say... 100,000 trillion meters?
So t = distance/velocity or t = m/v
But this velocity changes over distance, so I have to use integral.
t = m/v in dm
while v = m {distance}*H
so
##t = \int\frac{1}{Hx}dx##
##t = \frac{1}{H}\ln{(x)}##
I try to include 100,000 trillion metres in this equation, so
##t = 4.22 * 10^{17} * \ln{(10^{17})} = 4.22 * 10^{17} * 39.14 = 1.65 * 10^{19}##
So, it takes ... 5.24 * 10 11 years to reach 100,000 trillion metres. Okay...
Now, this. How long does it take to reach 1 meter?
Since ln(1) = 0, so it takes 0 seconds to reach 1 meter?
Did I make a mistake in my calculation?
This is my integral
Thank you very much.
[Add: I post this in General physics forum, not in Math forum, because I think even if it is mathematically correct, it's physically impossible?
What if there's an alien civilization where their meter and their seconds is not the same as ours. And our 1 meter is zero second?]
Space news on Phys.org
You are making a large number of unjustified assumptions among them:
  • The expansion of the universe occurs with a constant Hubble parameter.
  • The Hubble flow starts out at a distance of 1 m. (This sets the lower limit of your integral.)
Obviously, the latter of these assumptions directly implies zero time to reach a distance of 1 m. The fact that your final expression contains a logarithm of a parameter with physical dimension should be a huge warning sign.
@PeterDonis Thanks PeterDonis. You haven't forgot my previous question, and neither do I.
PeterDonis said:
My point is that you shouldn't ask them at all; you should first spend some time looking up references--...
Sean Carroll's lecture notes on GR ...
Thanks again
PeterDonis said:
Carroll's article gives a good overview of the issues involved here:
http://www.preposterousuniverse.com/blog/2010/02/22/energy-is-not-conserved/
Thanks @Orodruin for your reply. I'll study them.
It seems that I've been drifting a light year away from my original curiosity. The total energy of the (this?) universe is not zero. This has no well defined answer. Still I want to know why it doesn't. Thank you very much for your helps staffs/mentors. I'll do my own reading..
Orodruin said:
You are making a large number of unjustified assumptions...
Okay..., perhaps (and it's true) my math is very poor. My question is beyond my understanding. But, I read this...
Chronos said:
Redshift is largely the only yardstick we have for the distant universe. While it has served us well and made many confirmed predictions that does not 'prove' it is invincible. But, without it we are lost in illusions of reality. We must either place faith in observational evidence or our ancient religious beliefs. I believe the former offers us a better future.
from https://www.physicsforums.com/threads/what-are-quasars-made-of.877202/
Wiki states that: Hubble flow is 73km/sec per Mega persec
= 73km/sec per 3.26 million ly.
So, if the red shift indicates close to 300,000 km/sec then the distance would be... 13.397 billions light year.
Is this simply math concept correct?
So the galaxy that is 13.397 billions light year (nearly the age of the universe) run away from us at close to the speed of light?
Irrelevant. A galaxy that distant has left our observable universe and will redshift into oblivion long before any light it emits 'now' can ever reach us.
FAQ: Calculating Time to Reach 100,000 Trillion Meters in Hubble Flow | PF Forum
1. What is an integral in Hubble Flow?
An integral in Hubble Flow refers to the mathematical concept of integration, which is used to calculate the distance of a galaxy from Earth in relation to the expansion of the universe.
2. Why is the integral important in Hubble Flow?
The integral is important in Hubble Flow because it is used to calculate the Hubble Constant, which is a measure of the rate of expansion of the universe. This constant helps us understand the age and size of the universe.
3. How is the integral calculated in Hubble Flow?
The integral in Hubble Flow is calculated using a formula that takes into account the redshift of a galaxy, which is a measure of how much the universe has expanded since the light from that galaxy was emitted. The integral also considers the speed at which the galaxy is moving away from Earth.
4. What is the relationship between the integral and the Hubble Constant?
The integral and the Hubble Constant are directly related. The Hubble Constant is equal to the reciprocal of the integral, meaning that the integral is used to calculate the Hubble Constant.
5. Can the integral be used to measure the distance to all galaxies?
Yes, the integral can be used to measure the distance to all galaxies. However, it is more accurate for galaxies that are relatively close to Earth. For very distant galaxies, other methods such as supernova observations may be used to calculate their distance.
