MHB Integral Inequality: Prove $\left|f\left(\frac{1}{2}\right)\right|$ Bound
The discussion centers on proving the inequality $\left|f\left(\frac{1}{2}\right)\right| \le \int_0^1 |f(t)|\, dt + \frac{1}{2}\int_0^1 |f'(t)|\, dt$ for a continuously differentiable function $f$ defined on the interval [0,1]. Participants analyze various approaches, including considering the minimum values of $f$ on subintervals and using Riemann sums to establish bounds. A key point made is that replacing $f$ with $-f$ allows for the assumption that $f\left(\frac{1}{2}\right) \geq 0$. The discussion highlights the mathematical rigor involved in deriving the inequality through integration and properties of differentiable functions. The thread concludes with acknowledgment of effective solutions presented by participants.
Euge
MHB
POTW Director
Here's my first challenge!
Let $f : [0,1] \to \Bbb R$ be continuously differentiable. Show that
$\displaystyle \left|f\left(\frac{1}{2}\right)\right| \le \int_0^1 |f(t)|\, dt + \frac{1}{2}\int_0^1 |f'(t)|\, dt$.
Mathematics news on Phys.org
Nice challenge! ;)
We have:
$$f(x)=\int_0^x f'(t)\,dt \le \int_0^x |f'(t)|\,dt$$
If $f(x)<0$, we have:
$$-f(x)=\int_0^x -f'(t)\,dt \le \int_0^x |f'(t)|\,dt$$
Therefore:
$$|f(x)| \le \int_0^x |f'(t)|\,dt$$
It follows that:
$$\left|f\left(\frac 12\right)\right| \le \int_0^{1/2} |f'(t)|\,dt$$
By symmetry (or substitution of $u=1-t$):
$$\left|f\left(\frac 12\right)\right| \le \int_{1/2}^1 |f'(t)|\,dt$$
Adding them up and dividing by 2 tells us that:
$$\left|f\left(\frac 12\right)\right| \le \frac 12\int_0^1 |f'(t)|\,dt$$
And since $\int_0^1 |f(t)|\,dt \ge 0$, the requested result follows.
I'm glad you liked the challenge, ILS! You have a very good attempt, but you started out with an error in the first line. If you take $f(x) = 1$, then
$\displaystyle \int_0^{1/2}f'(t)\, dt = 0 \neq 1 = f\left(\frac{1}{2}\right)$.
[sp]Replacing $f$ by $-f$ if necessary, we may assume that $f\bigl(\frac12\bigr) \geqslant0.$
Suppost that the minimum value of $f$ in the interval $\bigl[0,\frac12\bigr]$ occurs at $a$, and the minimum value of $f$ in the interval $\bigl[\frac12,1\bigr]$ occurs at $b$. Then $\frac12\bigl(f(a) + f(b)\bigr)$ is the lower Riemann sum for $$\int_0^1f(t)\,dt$$ corresponding to the dissection $\{0,\frac12,1\}$, so that $$\tfrac12\bigl(f(a) + f(b)\bigr) \leqslant \int_0^1f(t)\,dt.$$
Next, $$\int_{1/ 2}^bf'(t)\,dt - \int_a^{1/ 2}f'(t)\,dt = f(b) - f\bigl(\tfrac12\bigr) - f\bigl(\tfrac12\bigr) + f(a).$$ It follows that $$\begin{aligned} f\bigl(\tfrac12\bigr) &= \tfrac12\!\bigl(f(a) + f(b)\bigr) + \tfrac12\!\!\int_a^{1/ 2}f'(t)\,dt - \tfrac12\!\!\int_{1/ 2}^bf'(t)\,dt \\ &\leqslant \int_0^1f(t)\,dt + \tfrac12\!\!\int_a^b|f'(t)|\,dt \\ &\leqslant \int_0^1|f(t)|\,dt + \tfrac12\!\!\int_0^1|f'(t)|\,dt. \end{aligned}$$[/sp]
This is an excellent solution. Thanks Opalg for participating!
I will show two of my solutions, both leading to the same equation that implies the result.
Solution 1.
By integration by parts,
$\displaystyle \int_0^1 f(t)\, dt = \int_0^{1/2} f(t)\, dt + \int_{1/2}^1 f(t)\, dt = \left(\frac{f\bigl(\tfrac{1}{2}\bigr)}{2} - \int_0^{1/2} tf'(t)\, dt\right) + \left(\frac{f\bigl(\tfrac1{2}\bigr)}{2} + \int_{1/2}^1 (1 - t)f'(t)\, dt\right) = f\bigl(\tfrac1{2}\bigr) - \int_0^{1/2} tf'(t)\, dt + \int_{1/2}^1 (1 - t)f'(t)\, dt.$
So,
$\displaystyle f\bigl(\tfrac1{2}\bigr) = \int_0^1 f(t)\, dt + \int_0^{1/2} tf'(t)\, dt - \int_{1/2}^1 (1 - t)f'(t)\, dt$,
and thus
$\displaystyle |f\bigl(\tfrac1{2}\bigr)| \le \int_0^1 |f(t)|\, dt + \frac{1}{2}\int_0^{1/2} |f'(t)|\, dt + \frac1{2}\int_{1/2}^1 |f'(t)|\, dt = \int_0^1 |f'(t)|\, dt + \frac{1}{2}\int_0^1 |f'(t)|\, dt.$
Solution 2.
For all $x \ge \tfrac1{2}$,
$\displaystyle f(x) = f\bigl(\tfrac1{2}\bigr) + \int_{1/2}^x f'(t)\, dt$.
Therefore
$\displaystyle \int_{1/2}^1 f(t)\, dt = \frac{f\bigl(\tfrac1{2}\bigr)}{2} + \int_{1/2}^1 \int_{1/2}^x f'(t)\, dt\, dx = \frac{f\bigl(\tfrac1{2}\bigr)}{2} + \int_{1/2}^1 \int_t^1 f'(t)\, dx\, dt$
$\displaystyle = \frac{f\bigl(\tfrac1{2}\bigr)}{2} + \int_{1/2}^1 (1 - t)f'(t)\, dt.$
Now we can write
$\displaystyle \frac{f\bigl(\tfrac1{2}\bigr)}{2} = \int_{1/2}^1 f(t)\, dt - \int_{1/2}^1 (1 - t)f'(t)\, dt.$
By a symmetric argument,
$\displaystyle \frac{f\bigl(\tfrac1{2}\bigr)}{2} = \int_0^{1/2} f(t)\, dt + \int_0^1 tf'(t)\, dt$.
Adding the latter two equations,
$\displaystyle f\bigl(\tfrac1{2}\bigr) = \int_0^1 f(t)\, dt + \int_0^{1/2} tf'(t)\, dt - \int_{1/2}^1 (1 - t)f'(t)\, dt.$
This leads to the result in exactly the same way as Solution 1.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
10K
10K
10K
10K
