Integral involving exponentials and the Time ordering operator
In summary, the conversation discusses manipulating an expression involving an infinite sum, integrals, and products of Hamiltonians. The concern is raised about the power of the integral and why a product of Hamiltonians can be written as a single one. The expert explains that the time ordering operator takes care of the non-commutativity of H with itself at different time instances.
vertices
62
How can I show that:
[tex]\sum^{\infty}_{n=0} \frac{(-i)^n}{n!} \int^{t}_{t'} dt_{1} dt_{2}...dt_{n} T(H_I(t_1)...H_I(t_n)) \equiv Texp[-i\int^{t}_{t'} dsH_I(s)][/tex]
My concern is that the integral
[tex]\int^{t}_{t'} dt_{1} dt_{2}...dt_{n} T(H_I(t_1)...H_I(t_n))[/tex]
is not raised to the power of 'n' so we can't really manipulate the expression on the LHS to fit:
[tex]exp(x)=\sum^{n=0}_{\infty}\frac{x^n}{n!}[/tex].
Also, why can you write a product of Hamiltonians as a single one - physically that makes no sense (to me anyway, a big qualification there!) ie why is HI(t1)HI(t2)...HI(tn)=HI(s)?
Thanks in advance...
All your questions relate to the power of the integral.
Can you write out what
[tex]\left( \int f(x) \, dx \right)^3 [/tex]
is (for some function f)?
I wish I could say:
[tex]\left( \int f(x) \, dx \right)^3 =\int dx f(x) \int dy f(y) \int dz f(z) [/tex]
as this would clearly solve the problem. But the variables in the integral in the OP aren't dummy variables - I would guess each hamiltonian is a different function of its respective variable, so I can't see how one can do what you've suggested?
Err, why not? I see an integral over t1 up to tn?
In principle (if H(t) was an ordinary function) you could immediately write
[tex]
\sum^{\infty}_{n=0} \frac{(-i)^n}{n!} \int^{t}_{t'} dt_{1} dt_{2}...dt_{n} H_I(t_1)...H_I(t_n) = \sum_{n = 0}^\infty \frac{(-i)^n}{n!} \left( \int^t_{t'} ds H(s) \right)^n
[/tex]
and define the exponential by the formal sum on the right hand side.
Exactly the same is happening here. The only thing that you need to take care of is the non-commutativity of H with itself at different time instances.
Anyway, it's not like (what you seem to imply) there are different definitions for H. For example, H may be defined as [itex]\hat H = \hat p^2 / 2m + m \omega^2 \hat x^2[/itex] such that H(t)H(t') is not H(t')H(t). But it is not true that H(t) = f(t) and H(s) = g(s) for different functions f and g.
Thanks CompuChip:) - that's a convincing explanation. I guess the the time ordering operator takes care of the non-commutativity of H with itself at different time instances.
FAQ: Integral involving exponentials and the Time ordering operator
What is an integral involving exponentials and the Time ordering operator?
An integral involving exponentials and the Time ordering operator is a mathematical expression used to calculate the expectation value of operators in quantum mechanics. It takes into account the time ordering of operators and the exponential evolution of the system.
How is the integral involving exponentials and the Time ordering operator used in quantum mechanics?
The integral involving exponentials and the Time ordering operator is used to calculate the transition probability between quantum states and to determine the time evolution of a quantum system.
What is the significance of the Time ordering operator in the integral involving exponentials?
The Time ordering operator ensures that the operators in the integral are arranged in the correct time order, which is crucial in quantum mechanics where the order of operations affects the outcome of measurements.
Can the integral involving exponentials and the Time ordering operator be solved analytically?
In most cases, the integral involving exponentials and the Time ordering operator cannot be solved analytically and must be approximated or solved numerically. However, there are some special cases where an analytical solution exists.
How does the integral involving exponentials and the Time ordering operator relate to the Schrödinger equation?
The integral involving exponentials and the Time ordering operator is a key component in the time-dependent Schrödinger equation, which describes the time evolution of a quantum system. It allows us to calculate the probability amplitude of a particle at a given time based on its initial state.
