Integral notation in physics and mathematics
In summary, the notation for multiple integrals in calculus and physics books may differ, with calculus books using two or three integral signs and physics books using only one. However, this is simply a matter of notation and both are correct. In some cases, the single integral notation may be more convenient, but for explicit integration, using multiple integral signs may be necessary. In terms of closed integrals, a closed volume in a hyperspace would correspond to a volume integral, while a closed line forms a surface integral and a closed surface forms a volume integral in three-dimensional space.
LucasGB
181
Why is it that every time I find an area or volume integral in my physics books, they are written using only one integral sign, while in calculus books they are written with two or three integral signs, respectively? Which one is more correct and rigorous?
Example?
In calculus books, vector flux is written as two integral signs (E . da). In physics books, vector flux is written as one integral sign (E . da). It's the concept of multiple integrals in calculus, which even though it is applied extensively to physics, it's done in a different notation. Which one is more correct?
It's not a matter of what is more rigorous or correct, it's a matter of notation. I guess that in a math exam, you'll be expected to write as many integral signs as needed, and to specify which integral corresponds to which variable, and in a physics exam they just won't care.
I guess physicts don't want to waste time on writing many integral signs :)
It depends what branch of mathematics you're talking about. Once you get into differential forms, you typically write only one integral sign, and often you are integrating over a space of arbitrary (but finite) dimension!
In R^3,
[tex]\int_{V} dV =\int\int\int dx dy dz[/tex]
Just a matter of notation, they are equivelent.
OK, so I take from this that I can write it the way I think looks best?
Well the first way is more convenient and brief for some manipulations, but if you are going to explicitly carry out the triple integration, you will probably want to start by writing it like that. So yea write it whichever way seems good to you.
Hi LucasGB! :smile:
(have an integral: ∫ :wink:)
You can't have more ∫s than ds …
so you can't have ∫∫∫ dV, but you can have ∫∫∫ dxdydz​
and you can't have less ∫s than ds except that, in my opinion :rolleyes:, you can have only one ∫, purely to save space. :wink:
That's important, I didn't know that. Well, alright then, I'll stick to the single ∫ notation, at times I don't have to explicitly carry out the integral. And another thing, the integral symbol with the small circle in it stands for a closed integral, right? So for a line integral, it means you take the integral over a closed loop, and for a surface integral, it means you take the integral over a closed surface. But what about a volume integral? What the hell is a closed volume? :smile:
I would guess that a closed volume will find the integral of a hypervolume in [tex]\mathbb{R}^4[/tex].
Yes, but what IS a closed volume? What's the difference between a closed and an open volume?
Sorry, my brain is limited to 3-D.
Oh, I get what you're saying. A closed line forms a surface, and a closed surface forms a volume. Therefore, a closed volume would form a hypervolume. I'm sorry, I hadn't grapsed that before, and was under the assumption that closed and open volumes were objects that could be understood in 3D. I get it now, thanks.
FAQ: Integral notation in physics and mathematics
What is integral notation and how is it used in physics and mathematics?
Integral notation is a mathematical notation used to represent the concept of integration, which is a mathematical operation that calculates the area under a curve. In physics, it is used to calculate various physical quantities such as displacement, velocity, acceleration, and work. In mathematics, it is used to solve problems related to finding the area, volume, and surface area of different shapes.
What are the different types of integrals in physics and mathematics?
There are two main types of integrals: definite and indefinite. A definite integral has specified limits of integration and gives a precise numerical value, while an indefinite integral does not have limits and gives a general expression. Other types of integrals include line integrals, surface integrals, and volume integrals, which are used to calculate quantities in three-dimensional space.
How is integral notation related to the derivative?
The derivative and integral are inverse operations of each other. The derivative calculates the instantaneous rate of change of a function, while the integral calculates the accumulated change over an interval. This relationship is known as the Fundamental Theorem of Calculus, and it allows us to easily switch between the two operations in problem-solving.
Can integral notation be used to solve real-world problems?
Yes, integral notation is widely used in solving real-world problems in various fields such as physics, engineering, economics, and more. It allows us to analyze and model real-world phenomena, such as motion, forces, and growth, by converting them into mathematical equations and using integration to find solutions.
Are there any common mistakes to avoid when using integral notation?
One common mistake to avoid is confusing the limits of integration. It is essential to carefully define the limits and understand their significance in the problem. Another mistake is forgetting to include the constant of integration when solving indefinite integrals. It is also crucial to properly apply integration techniques, such as integration by parts or substitution, to avoid incorrect solutions.
