Integral of 1/(1+cos(x)) Without Substitution Rule
In summary, the next function can be integrated using the substitution rule: $\frac 1 {1+cos(x)}=\frac 1 {1+(2\cos^2 (x/2)-1)}$, and the chain rule can be applied to the right hand side to find that $\tan \frac x 2 + C$ is the answer.
Yankel
395
Hello
I am trying to solve the integral of the next function:
1/(1+cos(x))
and without using the substitution rule...any ideas ?
thanks !
One could proceed as follows:
\(\displaystyle \frac{1}{\cos(x)+1}\cdot\frac{\cos(x)+1}{\cos(x)+1}=\frac{\cos(x)+1}{(\cos(x)+1)^2}= \frac{\cos(x)+\sin^2(x)+\cos^2(x)}{(\cos(x)+1)^2}=\)
\(\displaystyle \frac{(\cos(x)+1)\cos(x)-\sin(x)(-\sin(x))}{(\cos(x)+1)^2}= \frac{(\cos(x)+1)\frac{d}{dx}(\sin(x))-\sin(x)\frac{d}{dx}(\cos(x)+1)}{(\cos(x)+1)^2}=\)
\(\displaystyle \frac{d}{dx}\left(\frac{\sin(x)}{\cos(x)+1} \right)\)
Yankel said:
Hello
1/(1+cos(x))
thanks !
You can use
\(\displaystyle 1+\cos(x)= 2\cos^2\left(\frac{x}{2} \right)\)
or you can use that
\(\displaystyle \frac{1}{1+\cos(x)}=\frac{1-\cos(x)}{\sin^2(x)}\)
Yankel said:
Hello
1/(1+cos(x))
thanks !
You will have a LOT of difficulty trying to integrate this function without making a substitution.
Hello, Yankel!
[tex]\int \frac{dx}{1+\cos x}[/tex]
Multiply by [tex]\frac{1-\cos x}{1-\cos x}[/tex]
. . [tex]\frac{1}{1+\cos x} \cdot\frac{1-\cos x}{1-\cos x} \;=\;\frac{1-\cos x}{1-\cos^2x} \;=\;\frac{1-\cos x}{\sin^2x}[/tex]
. . [tex]=\;\frac{1}{\sin^2x} - \frac{1}{\sin x}\,\frac{\cos x}{\sin x} \;=\;\csc^2x - \csc x\cot x [/tex]Therefore:
.. [tex]\int(\csc^2x - \csc x\cot x)\,dx \;=\; -\cot x + \csc x + C[/tex]
Yankel said:
Hello
1/(1+cos(x))
thanks !
Since $\cos 2\alpha=2\cos^2\alpha-1$, we have:
$$\frac 1 {1+cos(x)} = \frac 1 {1+(2\cos^2 (x/2)-1)} = \frac 1 {\cos^2(x/2)} \cdot \frac 1 2$$
Since \(\displaystyle \tan'u=\frac 1 {\cos^2u}\), it follows that
$$\int \frac {dx} {1+cos(x)} = \int \frac 1 {\cos^2(x/2)} \cdot \frac 1 2 dx = \tan \frac x 2 + C$$
Verify by applying the chain rule to the right hand side.
FAQ: Integral of 1/(1+cos(x)) Without Substitution Rule
1. How do you find the integral of 1/(1+cos(x)) without using the substitution rule?
To find the integral of 1/(1+cos(x)) without using the substitution rule, you can use the trigonometric identity cos(x) = 1 - 2sin^2(x/2) to rewrite the integral as 1/(1+cos(x)) = 1/(2cos^2(x/2)). Then, using the trigonometric identity sec^2(x/2) = 1 + tan^2(x/2), you can rewrite the integral again as 1/(2cos^2(x/2)) = 1/(4sec^2(x/2) - 2). Finally, you can use the substitution u = tan(x/2) to solve the integral as 1/(4u^2 - 2)du, which can be solved using partial fractions.
2. Can you explain why the substitution rule cannot be used to solve the integral of 1/(1+cos(x))?
The substitution rule, also known as u-substitution, is used to solve integrals where the integrand can be rewritten in terms of a new variable u. However, in the case of 1/(1+cos(x)), there is no simple way to rewrite the integrand in terms of u, making the substitution rule ineffective in solving this integral.
3. Is there a specific method or formula that can be used to solve the integral of 1/(1+cos(x))?
Yes, there is a specific method that can be used to solve the integral of 1/(1+cos(x)). This method involves rewriting the integrand using trigonometric identities and then using partial fractions to solve the integral.
4. Are there any other ways to approach the integral of 1/(1+cos(x)) without using the substitution rule?
Yes, there are other ways to approach the integral of 1/(1+cos(x)) without using the substitution rule. One way is to use the half-angle formula cos^2(x/2) = (1+cos(x))/2 to rewrite the integral as 2/(1+cos(x)), which can then be solved using the trigonometric identity sec^2(x) = 1 + tan^2(x). Another approach is to use the trigonometric identity sin^2(x/2) = (1-cos(x))/2 to rewrite the integral as 2/(1-cos(x)), which can then be solved using the substitution rule.
5. Can the integral of 1/(1+cos(x)) be solved using any other mathematical concepts or techniques?
Yes, the integral of 1/(1+cos(x)) can also be solved using complex numbers. By converting the cosine function into exponential form and using Euler's formula, the integral can be rewritten as the sum of two complex integrals which can then be solved using techniques from complex analysis. However, this approach may be more advanced and not typically used in introductory calculus courses.
