Integral of [1/sqrt(8x-x^2)] dx - Daisy Dee's Answer at Yahoo Answers
In summary, we are asked to evaluate the definite integral of 1 over the square root of 8x-x^2, and we use a trigonometric substitution to simplify the expression and find the solution to be the inverse sine of (x-4)/4 plus a constant.
MarkFL
MHB
13,288
Here is the question:
Integrate [1/sqrt of (8x-x^2)] dx?
I have posted a link there to this thread so the OP can see my work.
Mathematics news on Phys.org
Re: Daisy Dee's question: evaluating a definite integral where a trig. substitution is appropriate
Hello Daisy Dee,
We are given to evaluate:
\(\displaystyle I=\int\frac{1}{\sqrt{8x-x^2}}\,dx\)
We find that the domain of the integrand is $(0,8)$.
Completing the square on the radicand, we obtain:
\(\displaystyle I=\int\frac{1}{\sqrt{4^2-(x-4)^2}}\,dx\)
Using the substitution:
\(\displaystyle x-4=4\sin(\theta)\,\therefore\,dx=4 \cos(\theta)\,d\theta\)
We may write:
\(\displaystyle I=\int\frac{4\cos(\theta)}{\sqrt{4^2-4^2\sin^2(\theta)}}\,d\theta\)
For \(\displaystyle -\frac{\pi}{2}<\theta<\frac{\pi}{2}\) we may write:
\(\displaystyle I=\int\,d\theta=\theta+C\)
Back substituting for $\theta$, we obtain:
\(\displaystyle I=\sin^{-1}\left(\frac{x-4}{4} \right)+C\)
FAQ: Integral of [1/sqrt(8x-x^2)] dx - Daisy Dee's Answer at Yahoo Answers
How do you solve the integral of [1/sqrt(8x-x^2)] dx?
The integral of [1/sqrt(8x-x^2)] dx can be solved by using the substitution method. Let u = 4x - 4, then du = (4-4x)dx. After substituting, the integral becomes ∫[1/u^(1/2)]du. This can be solved using the power rule for integrals, giving a final answer of 2√u + C. Substituting back in for u, the final answer is 2√(4x-4) + C.
What is the domain of [1/sqrt(8x-x^2)]?
The domain of [1/sqrt(8x-x^2)] is all real numbers except for 0 and 8. This is because the expression is undefined when the denominator, √(8x-x^2), is equal to 0 or when the radicand, 8x-x^2, is negative.
Can the integral of [1/sqrt(8x-x^2)] dx be solved using another method?
Yes, the integral of [1/sqrt(8x-x^2)] dx can also be solved using the trigonometric substitution method. By letting x = 4sin^2θ, the integral can be rewritten as ∫[1/(4sinθ)](8cosθ) dθ. This can then be solved using the power rule for integrals and trigonometric identities.
How does the graph of [1/sqrt(8x-x^2)] compare to its integral?
The graph of [1/sqrt(8x-x^2)] is a semi-circle with a maximum value of 1 and a minimum value of 0. The graph of its integral, 2√(4x-4) + C, is a parabola with a minimum value of 0 and no maximum value. This means that the integral will always be greater than or equal to the original function.
Can the integral of [1/sqrt(8x-x^2)] dx be evaluated using a calculator?
Yes, most graphing calculators have a built-in integral function that can be used to evaluate the integral of [1/sqrt(8x-x^2)] dx. However, it is important to note that the calculator may not be able to provide an exact answer and may only give an approximation.
