Integral of 1 / (x^2 + 2) dx ?
In summary: I think the issue is for the OP to do the integration and not just look it up as a 'standard' integral. My point is if you do the integration on both, they are the same difficulty are they...?
  • #36
bob012345 said:
Is there some simple easy trick I am missing that makes this much easier than ? You can tell me privately if you wish.
Please take a look at attached calculation.
Likes bob012345
  • #37
Thanks. It does seem simpler with the ##1## in the denominator.
  • #38
ergospherical said:
@bob012345, multiply the identity ##\dfrac{1}{(x+3i)(x-3i)} = \dfrac{A}{x + 3i} + \dfrac{B}{x-3i}## by the factor ##(x-3i)##, and then set ##x = 3i## (you can do this because the identity holds for all ##x##). And do a similar thing to find ##A##.
But for x=3i makes some of the denominators of the identity zero...
  • #39
If you multiply both sides by one of the factors, say ##x-3i##, solve for ##A## and then set ##x=3i## it works. Cancel those terms before you make the substitution.
  • #40
That's the idea, so you can find A, then do x=-3i and find B.
  • #41
I think it is being suggested this is like the proof ##1=2##.
  • #42
Emmm, by multiplying both sides by (x-3i) and then making x=3i, you will not fall into any error, it is valid to do so.
  • #43
It should not have been left to the reader to do first the multiplication of the identity by x-3i, it should have been explicitly mentioned by @ergospherical :D.
  • #44
You can think of it like this:
\begin{align*}
\lim_{x \to 3i} (x-3i)\frac{1}{(x-3i)(x+3i)} &= \lim_{x \to 3i} (x-3i)\left[\frac{A}{x-3i}+\frac{B}{x+3i}\right] \\
\lim_{x \to 3i} \frac{1}{x+3i} &= \lim_{x \to 3i} \left[A+B\frac{x-3i}{x+3i}\right] \\
\end{align*} After canceling the factors of ##x-3i##, the functions are continuous at ##x=3i##, so you can evaluate the limit by simply plugging in the value.
Likes SammyS
  • #45
This is exactly how I would do it.
  • #46
No, not at all. I think you might be referring to the post by ergospherical.
An important point is that the equation above is an identity: one that is is true for all values of the variable x, excepting only ##x = \pm 3i##. For any values of x other than these two, we can multiply both sides of the equation by ##(x + 3i)(x - 3i)## to get this equation:
##1 = A(x - 3i) + B(x + 3i)##
The new equation is still an identity: it must be true for any value of x. The way I chose to go is to solve for A and B like so:
##1 = (A + B)x - 3i(A - B)
For this to be true for all values of x, A + B must be 0 (there is no x term on the left side), and -3i(A - B) = 1.
Solve these two equations for A and B, and Bob's your uncle.
Likes benorin, bob012345 and Tapias5000
  • #47
hehe, I use Quora more so my answers are usually complete aum, I'm not used to this forum at all hehe. :sorry:
  • #48
Then
[tex]\int \frac{dx}{x^2+2}= \frac{1}{\sqrt{2}}\int\frac{d\frac{x}{\sqrt{2}}}{(\frac{x}{\sqrt{2}})^2+1}=...[/tex]
Likes benorin and Delta2
  • #49
mitochan said:
Then
I just used a basic trig with ##tan(\theta)= \large\frac{x}{a}## and it worked fine.
  • #50
The image in post #36 shows why this substitution works. For ##x^2 + 2##, the length of the leg adjacent to the angle is ##\sqrt 2## rather than 1.
  • #51
Of course and the point I made was the method I used works for any ##a##. That's why I used ##a## and not ##1##. I found it easier than manipulating the integral first to make it a ##1## or using complex numbers.
  • #52
Now try it with a hyperbolic trig substitution.
  • #53
I tried it and it was not easier by any means.
  • #54
I think that the most straightforward way is to factorise ##x^2+2## into ##2\left(1+x^2/2\right)=2\left[1+(x/\sqrt 2)^2\right]##.
When you see an integral close to one that you would usually find in an integration table, ##(1+x^2)^{-1}## for instance, try adding a ##0## or factorising something.
Likes benorin
  • #55
You guys have beaten this integral in a few ways, OP did you follow any of them? The easy way involves ##1+\left(\tfrac{x}{\sqrt{2}}\right) ^2## and a trig substitution. You probably haven’t learned series methods yet but that would of course be much harder.
I think you can safely lock this thread.
