Integral of 1/(x*ln(x)) converging or diverging?
In summary, the conversation discusses different approaches for finding the integral of 1/(x*ln(x)) dx, ultimately concluding that the improper integral with lower limit 2 and upper limit infinity diverges.
ndnbolla
In order to find the integral of 1/(x*ln(x)) dx, I tried using the substitution method where
u = 1/x and dv = 1/ln(x) dx .
Then du = ln(x) dx.
However this is where I got stuck.
What would v equal? Or is their another way I should be approaching this integral in order to find if it is diverging or converging and if converging, to what value?
First of all, is it a definite integral? What are the limits of integration?
Then, if u=1/x then du is not ln(x) dx. Why don't you try the substitution u=ln(x) and see what happens?
My mistake and sorry for not mentioning the limits. Its an improper integral with lower limit 2 and upper limit infinity.
I think I found the solution...
u=ln(x)
du=(1/x)
int(1/u) du
And then solve for the integral, with the lower limit being ln(2) and the upper limit being infinity.
It ends up diverging, correct?
Yes, I think you're right.
Related to Integral of 1/(x*ln(x)) converging or diverging?
What is the integral of 1/(x*ln(x))?
The integral of 1/(x*ln(x)) is given by ln(ln(x)) + C, where C is the constant of integration.
What is the domain of the function 1/(x*ln(x))?
The domain of the function 1/(x*ln(x)) is (0, ∞), as the function is undefined at x = 0 and approaches infinity as x approaches infinity.
Does the integral of 1/(x*ln(x)) converge or diverge?
The integral of 1/(x*ln(x)) converges, as ln(ln(x)) approaches infinity as x approaches infinity, and therefore the integral does not have a finite limit.
What is the limit of the integral of 1/(x*ln(x)) as x approaches infinity?
The limit of the integral of 1/(x*ln(x)) as x approaches infinity is infinity, as ln(ln(x)) approaches infinity as x approaches infinity.
Can the integral of 1/(x*ln(x)) be solved using substitution?
Yes, the integral of 1/(x*ln(x)) can be solved using substitution by letting u = ln(x) and du = 1/x dx. This results in the integral becoming ∫1/u du, which is equal to ln(u) + C, or ln(ln(x)) + C.
