Integral of Bessel J1 -> Struve?
In summary, the integral of x*J1(x) dx results in pi*x/2*[J1(x)*H0(x) - J0(x)*H1(x)], where H0 and H1 are Struve functions. If the integral is a definite integral with well-defined values, then show these values.
labaki
Hello, everyone.
I have to solve the integral of x*J1(x) dx,
in which J1 is the Bessel function of first kind
and order 1. I found out that this results in
in which H0 and H1 are Struve functions.
My prof told me Struve functions are not
necessary, though. He says I could get to a
much simpler solution, but didn't have time to
tell me which solution.
Do you guys have any idea?
Thanks!
As far as I know, the ways to express the solutions are Struve functions, or hypergeometric functions, or infinite series. Nothing more.
Of course, if it was definite integral (for example 0 to infinity) the solution would be much simpler in some cases.
Hi, JJacquelin, thanks for your repply.
It is in fact a definite integral, say, from a to b.
Would there be any simplification in this case?
No simplification in case of any a and b.
Simplification might occur in some particular cases (for example a=0 and b=infinity). Each case requires a specific study (often difficult) in order to see if simplification is possible or not.
So, if the integral really is a definite integral, say, not with any a,b, but with well defined values, then show these values.
labaki said:
Hello, everyone.
Thanks!
I have run into essentially the same integral in the past and have found nothing better. I ended up needed numerical evaluation of this anyway, so gave up on closed-form results eventually and resorted to more standard numerical techniques.
If your prof ever tells you his solution please share it with us - at the very least it will be interesting to see his definitions of "solution" and "simpler".
jason
FAQ: Integral of Bessel J1 -> Struve?
What is the definition of the integral of Bessel J1 to Struve?
The integral of Bessel J1 to Struve is a mathematical operation that calculates the area under the curve of the Bessel function J1, which is a special function that appears in many areas of mathematics and physics. This integral is often used to solve problems involving oscillatory systems.
How is the integral of Bessel J1 to Struve calculated?
The integral of Bessel J1 to Struve is typically calculated using numerical methods, such as the trapezoidal rule or Simpson's rule. These methods involve dividing the area under the curve into smaller, simpler shapes and then using mathematical formulas to estimate the area of each shape. The estimates are then added together to obtain the final value of the integral.
What are the applications of the integral of Bessel J1 to Struve?
The integral of Bessel J1 to Struve has many applications in physics, engineering, and other scientific fields. It is often used to solve problems related to wave propagation, heat transfer, and electrical circuits. It also appears in the solution of differential equations and in the study of special functions.
Is the integral of Bessel J1 to Struve a difficult concept to understand?
The integral of Bessel J1 to Struve can be challenging to understand for those who are not familiar with advanced mathematics. However, with proper training and practice, it can be understood by anyone. It is important to have a strong foundation in calculus and mathematical analysis to fully grasp the concept.
Are there any other special functions related to the integral of Bessel J1 to Struve?
Yes, there are several other special functions that are related to the integral of Bessel J1 to Struve. These include the Struve function H1, the Airy function, and the modified Bessel function of the first kind. Each of these functions has its own unique properties and applications, and they are often used in conjunction with the integral of Bessel J1 to Struve to solve complex problems.
