Integral of differential cross section over solid angle
In summary: However, with a bit of perseverance you will finally be able to get through the material and understand it.
ck99
61
Find σ , the differential cross section, starting from the expression below and integrating over solid angle Ω
dσ/dΩ = r2sin2θ
dσ = r2sin2θ dΩ
I remember that dΩ = sinθ dθ dμ
and doing the μ integral from 0 to 2∏ gives dΩ = 2∏ sinθ dθ
substitute into get dσ = 2∏ r2sin2θ sinθ dθ
Now, the next step in the textbook is to substitute u = cos θ and write
σ = 2∏r2∫(1-u2)du with u = cos θ and integration limits from -1 to 1.
I have played around with this step for a while and I know the trig identity sin2 θ = 1 - cos2 θ, but I still don't get how to do this step properly. I think I'm suppose to put a du/dθ term in there, which is a -sinθ term, but I can't see how they get to the final expression in the book, which is
σ = 8∏/3
If anyone can help me work through these steps in detail I would really appreciate it; I should know how to do this by now (4th year physics MSc student!) but it's like my brain switches off every time I see the ∫ symbol and I have to learn everything from scratch every term . . . :(
So when you substitute u = cos θ, you have to remember to change the integration measure as well. Using the chain rule, you have du = du/dθ dθ.
And yeah this is something you should really really really know. I suggest you go to the library, check out one of those massive analysis textbooks and go through it carefully until you at least understand the basics.
Thanks clamtrox. I am sure I am on the right track, I just can't remember how to make it work properly. Using the trig identity from before, I can write
σ = 2∏r2 ∫(1-cos2 θ) sin θ dθ
by the chain rule, substitute dθ with (du/dθ)dθ
σ = 2∏r2 ∫(1-cos2 θ) sin θ (du/dθ)dθ
If u = cos θ then du/dθ = -sinθ
Substitute in u and cancel the dθ terms with each other (not sure I am doing this bit right!)
σ = 2∏r2 ∫(1-u2) sin θ (-sin θ) du
So I go wrong where I try to manipulate the (du/dθ)dθ part of the expression. I am trying to say that
(du/dθ)dθ = du (1/dθ) dθ = du
and cancel out the dθ terms to just leave du. But I know I am supposed to actually evaluate the du/dθ term!
They do it by saying
sin θ dθ = du where u = cos θ [A]
and it's this part I don't understand.
If I integrate the two parts of the expression in line [A] I get
∫sin θ dθ = -cos θ
∫du = u, or = cos θ
so ∫sin θ dθ ≠ ∫du
and I am even more confused!
No! dθ≠(du/dθ)dθ!
Of course it isn't . . . .
If I try
du = du/dθ dθ
du = -sin θ dθ
dθ = 1/(-sin θ) du
Now the original expression
becomes
σ = 2∏r2 ∫(1-u2 θ) sin θ/(-sin θ) du
σ = 2∏r2 (-∫(1-u2 θ) du)
And I think -∫ = ∫ with the limits swapped.
This is good! However I would just like to check that I have worked out the integral limits properly?
For the solid angle of a sphere, dμ is integrated from 0 to 2∏
and sinθ dθ is integrated from 0 to ∏. I take this to mean that the integral
should also be evaluated from 0 to ∏ - is this correct?
These limits go from (0, ∏) to (-1, 1) because of the substitution, and to (1, -1) because I changed the sign of the integral. I evaluate the integral to get
- [(1/3)u3] (limits from 1,-1)
(1 - (-1)) - 1/3(1 - (-1))
2 - 2/3
4/3
So σ = 2∏r2 (4/3) = (8∏r2)/3 as required.
I don't know why I find it so difficult really; by the end of last year I was doing 4D GR calculus stuff with no trouble, but after a couple of months off it's like pulling teeth again and I am sub A-level standard!
Yap now it looks pretty good.
I would still recommend you try to study analysis again. It's pretty easy and fast to learn, and it is something you have to be absolutely comfortable using if you plan on working in any job even slightly related to physics.
Often it takes some time to learn how to study stuff efficiently, and it's not uncommon to have to go back to the courses taught in the first years and go through the material again.
Related to Integral of differential cross section over solid angle
1. What is the definition of the "Integral of differential cross section over solid angle"?
The integral of differential cross section over solid angle is a mathematical concept used in physics to calculate the total amount of scattered radiation or particles over a specific solid angle. It is commonly denoted as ∫Ωσ(Ω)dΩ, where σ is the differential cross section and Ω represents the solid angle.
2. How is the "Integral of differential cross section over solid angle" used in experimental physics?
In experimental physics, the integral of differential cross section over solid angle is used to determine the probability of a particle being scattered in a particular direction. It is also used to calculate the total scattering cross section, which is a measure of how likely a particle is to scatter when interacting with a target.
3. What is the significance of the "Integral of differential cross section over solid angle" in quantum mechanics?
In quantum mechanics, the integral of differential cross section over solid angle is used to calculate the scattering amplitudes, which provide important information about the interaction between particles. It is also used to study the scattering of particles in different energy regimes and to understand the behavior of particles at the quantum level.
4. How is the "Integral of differential cross section over solid angle" related to other mathematical concepts?
The integral of differential cross section over solid angle is closely related to the differential cross section itself, as it is used to calculate the total amount of scattered radiation or particles. It is also linked to other mathematical concepts such as solid angle, which is a measure of the size of an object as seen from a specific point, and integration, which is the process of finding the area under a curve.
5. Can the "Integral of differential cross section over solid angle" be applied in other fields of science?
Yes, the integral of differential cross section over solid angle can be applied in various fields of science such as astrophysics, nuclear physics, and particle physics. It is a useful tool for studying the scattering of particles and radiation, and can also be used to analyze the properties of different materials and objects.
