Integral of Exponential Fractions with Positive Parameters
In summary, the conversation discusses finding the integral for positive parameters $a$, $b$, and $c$. The solution is shown to be $F = b-a + a \ln \left(\frac{a}{c} \right) - b \ln \left(\frac{b}{c} \right)$. The experts also discuss alternative methods for finding the constant $C$ in the integral, such as setting $a=b$ or using the upper incomplete gamma function.
polygamma
229
Show that for positive parameters $a$, $b$, and $c$,
$$ \int_{0}^{\infty} \left( \frac{e^{-ax}-e^{-bx}}{x^{2}} + (a-b) \frac{e^{-cx}}{x} \ \right) \ dx = b-a + a \ln \left(\frac{a}{c} \right) - b \ln \left(\frac{b}{c} \right)$$
Mathematics news on Phys.org
[sp]
\(\displaystyle F = \int_{0}^{\infty} \left( \frac{e^{-ax}-e^{-bx}}{x^{2}} + (a-b) \frac{e^{-cx}}{x} \ \right) \ dx\)
\(\displaystyle F_a =\int_{0}^{\infty} \frac{e^{-cx}-e^{-ax}}{x}\ dx = \ln \left( \frac{a}{c}\right) \)
\(\displaystyle F= a \ln \left( \frac{a}{c}\right) - a + C \)
\(\displaystyle F_b = C_b\)
\(\displaystyle F_b = \int_{0}^{\infty} \frac{e^{-bx}-e^{-cx}}{x} dx = -\ln \left( \frac{b}{c}\right)\)
We have \(\displaystyle C_b = -\ln \left( \frac{b}{c}\right)\) so
\(\displaystyle C = -b\ln \left( \frac{b}{c}\right)+b\)
\(\displaystyle F = b-a +a \ln \left( \frac{a}{c}\right)-b\ln \left( \frac{b}{c}\right)\)
[/sp]
@ Zaid
I actually didn't even consider differentiating inside of the integral.
I took the boring approach of finding an antiderivative in terms of the exponential integral and then using the expansion of the exponential integral at $x=0$ to evaluate the antiderivative at the lower limit.
There is one thing about your evaluation that I'm not sure about, though.
When you integrated to find the constant $C$, how did you know that he constant of integration was zero?
Alternatively what you could do to find $C$ is to let $a=b$ in the original integral.
Yeah, I made the evaluations not clear but I actually considered that $C$ as a function of $b$ so I differentiated with respect to $b$. Again putting $a=b$ is by far much clearer.
Can you post your approach ?
It's easier to work the upper incomplete gamma function.
[tex] \Gamma(0,a x) = -\text{Ei}(- ax) = \int_{ax}^{\infty} \frac{e^{-t}}{t} \ dt = \int_{x}^{\infty} \frac{e^{-au}}{u} \ du[/tex]Let's first derive the expansion at $x=0$.
$$ \Gamma(0,x) = \int_{x}^{\infty} \frac{e^{-t}}{t} \ dt = \int_{1}^{\infty} \frac{e^{-t}}{t} \ dt - \int_{1}^{x} \frac{e^{-t}}{t} \ dt $$
$$ = \int_{1}^{x} \frac{1-e^{-t}}{t} \ dt - \ln x + \int_{1}^{\infty} \frac{e^{-t}}{t} \ dt$$
$$= -\ln x + \Big( -\int_{0}^{1} \frac{1-e^{-t}}{t} \ dt + \int_{1}^{\infty} \frac{e^{-t}}{t} \ dt \Big) + \int_{0}^{x} \frac{1-e^{-t}}{t} \ dt$$
$$ = - \ln x - \gamma - \int_{0}^{x} \frac{e^{-t}-1}{t} \ dt$$
$$ = - \ln x - \gamma \int_{0}^{x} \Big(-1 + \frac{t}{2} - \frac{t^{2}}{6} + \ldots \Big) \ dt$$
$$ = - \ln x - \gamma + x + \mathcal{O}(x^{2}) $$And it's not really needed here, but one can find an asymptotic expansion at $x= \infty$ by integrating by parts.
$$ \Gamma(0,x) \sim \frac{e^{-x}}{x} + \mathcal{O}\left( \frac{e^{-x}}{x^{2}} \right) \ \ x \to \infty$$Then
$$ \int \left( \frac{e^{-ax}-e^{-bx}}{x^{2}} + (a-b) \frac{e^{-cx}}{x} \ \right) \ dx = \int \frac{e^{-ax}-e^{-bx}}{x^{2}} \ dx + (a-b) \int \frac{e^{-cx}}{x} \ dx$$
$$ = -\frac{e^{-ax} -e^{-bx}}{x} + \int \frac{-ae^{-ax}+be^{-bx}}{x} \ dx -(a-b) \Gamma(0,cx)$$
$$ = \frac{e^{-bx} -e^{-ax}}{x} + a \Gamma(0,ax) - b \Gamma(0,bx) - (a-b) \Gamma(0,cx)+C$$$$ \int^{\infty}_{0} \left( \frac{e^{-ax}-e^{-bx}}{x^{2}} + (a-b) \frac{e^{-cx}}{x} \ \right) \ dx$$
$$ = 0 - \lim_{x \to 0} \left[ \frac{e^{-bx} -e^{-ax}}{x} + a \left(-\ln ax - \gamma \right) - b \left(-\ln bx - \gamma \right) -(a-b) \left(-\ln cx - \gamma \right) \right]$$
$$= - \lim_{x \to 0} \left[ \frac{e^{-bx} -e^{-ax}}{x} - a \ln \left(\frac{a}{c} \right) + b \left(\frac{b}{c} \right) \right]$$
$$ = b-a + a \ln \left(\frac{a}{c} \right) - b \ln \left(\frac{b}{c} \right) $$
FAQ: Integral of Exponential Fractions with Positive Parameters
What is the definition of the integral of exponential fractions with positive parameters?
The integral of exponential fractions with positive parameters is a mathematical operation used to find the area under a curve defined by an exponential fraction with positive parameters. It is denoted by the symbol ∫ and is typically evaluated using the rules of integration.
What are the steps for evaluating the integral of exponential fractions with positive parameters?
The steps for evaluating the integral of exponential fractions with positive parameters are as follows:
  1. Identify the integral form of the exponential fraction.
  2. Use algebraic manipulation to simplify the fraction, if necessary.
  3. Apply the rules of integration to find the antiderivative of the fraction.
  4. Substitute the limits of integration and evaluate the integral.
What are some common examples of exponential fractions with positive parameters?
Some common examples of exponential fractions with positive parameters include:
  • e^x/(x+1)
  • 3^x/(x^2 + 1)
  • (2x+1)^3/(x^2 + 2x + 3)
Can the integral of exponential fractions with positive parameters be evaluated using numerical methods?
Yes, the integral of exponential fractions with positive parameters can also be evaluated using numerical methods such as the trapezoidal rule, Simpson's rule, or Monte Carlo integration. These methods are useful when the integral cannot be evaluated analytically.
What are some real-world applications of the integral of exponential fractions with positive parameters?
The integral of exponential fractions with positive parameters has several real-world applications, including calculating the growth of bacteria populations, determining the rate of radioactive decay, and modeling the spread of diseases. It is also used in physics and engineering to analyze systems with exponential growth or decay.
