Integral of f·g ≠ integral f · integral g [True or False]
  • Thread starter Thread starter MiddleEast
    Integral
MiddleEast
True or False : Integral of f·g ≠ integral f · integral g
NA
My answer is False! I think must stated "in general," in the beginning of the statement. Cause this could be true if f or g = zero. There may be other cases also.
Is my answer right?
If integral of f·g ≠ integral f · integral g is false, then integral of f·g = integral f · integral g.
Thus this make sense?
Hmmm. Good point! The issue here is that my point is "sometime true sometimes false" & your point "If it not true, then it is always false". huge difference between my point of view and yours! I believe it has something to do with "logical mathematics" if there is something called so.
The issue if you said it is true then I have my counter-example.
You obviously understand the point, and the answer at this stage is semantics over the implicit qualifier. I think it's a confusing question.
Likes FactChecker
There's no clear notation in mathematics for "not necessarily equal to". The best we can do is say something like, for example:
For functions ##f## and ##g## in general ##f \circ g \ne g \circ f##. Even though there are cases where equality holds.
Likes SammyS and FactChecker
in my opinion, if the answer can only be true or false, that implies to me that the statement is universally quantified, so i would argue the correct answer should be false. since the statement is not explicitly quantified however, one could argue that it is poorly posed.
Likes Office_Shredder
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
