: Integral of (n+1)th derivative
In summary, the conversation discusses how to solve the equation for the integral of the (n+1)th derivative. The solution involves using the hint to integrate by parts and then using induction to show that the equation holds. The final step is to compute the integral for n=1 and then apply the integration by parts method. The conversation ends with a note of gratitude for the explanation.
kfdleb
URGENT: Integral of (n+1)th derivative
let f(n+1) be integrable on [a;b]; show that
f(b)=[tex]\sum[/tex] [tex]\frac{f(r)(a)}{r!}[/tex](b-a)r +[tex]\frac{1}{n!}[/tex] [tex]\int^{a}_{b}[/tex]f(n+1)(t)(b-t)ndthint:integrate by parts and use inductionPLEASE any idea about how to solve it would be really appreciated... I've been trying for more than an hour but no idea
Well use the hint. Induct on n. For n = 1, show the equation holds by computing the integral that you get on the RHS after setting n = 1. This is fairly straightforward.
Start by actually doing the integration by parts. Treat the integral as u*dv where u=f^(n+1)(t) and dv=(b-t)^n*dt. Once you've got that straight then start worrying about the induction.
10x a lot
FAQ: : Integral of (n+1)th derivative
What is the meaning of the integral of (n+1)th derivative?
The integral of (n+1)th derivative is a mathematical concept that represents the area under the curve of the (n+1)th derivative of a function. It is computed by taking the antiderivative of the (n+1)th derivative. This integral is useful in many areas of science, particularly in physics and engineering.
How is the integral of (n+1)th derivative different from a regular integral?
The integral of (n+1)th derivative is different from a regular integral because it involves taking the antiderivative of a higher order derivative. This means that the resulting function will have a higher degree polynomial than the original function, and it may also have multiple constants of integration.
What is the purpose of finding the integral of (n+1)th derivative?
The purpose of finding the integral of (n+1)th derivative is to gain a better understanding of the behavior of a function. It can also help in solving differential equations and in finding the maximum and minimum values of a function.
Can the integral of (n+1)th derivative be negative?
Yes, the integral of (n+1)th derivative can be negative. This can happen when the function has a negative slope and the area under the curve is below the x-axis. In this case, the integral will be negative, indicating that the function is decreasing over that interval.
How can the integral of (n+1)th derivative be used in real-world applications?
The integral of (n+1)th derivative has many real-world applications, such as in physics, engineering, and economics. It can be used to calculate the work done by a force, the velocity of an object, and the change in temperature over time. It is also used in optimization problems to find the maximum or minimum value of a function.
