Integral of product of infintesimal volume
In summary, the formula for the energy stored in a charge configuration, given by the integral of the product of the infinitesimal volume with the square of the electric field, is always positive due to the consideration of fabrication of charges. However, when calculating the energy for a charge configuration, such as a spherical or cylindrical shape, the formula may seem to take into account the infinite energy required for fabrication of all the charges. This is because point charges are just models and all spherical charge distributions appear as point charges from the outside. In the case of equal and opposite charges, the energy calculated using the formula may seem to be both positive and negative. This is due to the fact that the work required to move the charges into position is independent of
vijaypandey93
I'm following the book ''introduction to electrodynamics by D.J. Griffiths''. As he has written that the formula ''integral of product of infintesimal volume with the square of electric field'' gives us the energy contained in a charge configuration that is always positive because we're encountering square.He has justified it by saying that it even considers the fabrication of charges and as we know the fabrication of point charge involves infinite energy.But why do i get a definite value when i calculate the energy of a charge configuration like spherical or cylindrical,rather if I'm following his argument correctly then in spherical,this formula should take into account of fabrication of all the charges and that's certainly infinite.what's that in his argument that I'm not getting?Please help!
okay but what'd we get if we calculate the energy due to equal and opposite charges?should it be positive or negative?according to the formula statrd above,it'll always be positive.and using the formula [k(q1)(q2)]/r,it's negative.can you please justify how?
Your confusion is understandable, as the concept of infinite energy can be difficult to understand. However, in this context, the term "infinite energy" does not refer to an actual infinite amount of energy, but rather to the fact that the energy of a point charge is theoretically infinite due to its infinitesimal size. This means that the energy calculated using the formula for the integral of the product of infinitesimal volume and the square of the electric field will always be positive, regardless of the charge configuration.
In the case of a spherical or cylindrical charge configuration, the formula still holds true, but the energy calculated will be a finite value. This is because the charges in these configurations are not point charges, they have a finite size and therefore do not have infinite energy. The formula takes into account the distribution of charges within the volume, rather than considering each charge as a point.
So, while the formula may seem to contradict the concept of infinite energy, it is simply a mathematical representation of the energy contained in a charge configuration, and the actual energy will always be a finite value. I hope this helps to clarify the concept for you.
FAQ: Integral of product of infintesimal volume
What is the definition of the integral of product of infinitesimal volume?
The integral of product of infinitesimal volume is a mathematical concept that calculates the total volume of a three-dimensional object by dividing it into infinitely small volumes and summing them up.
What is the purpose of using the integral of product of infinitesimal volume?
The purpose of using the integral of product of infinitesimal volume is to accurately calculate the volume of complex three-dimensional objects that cannot be easily measured or approximated by traditional methods.
How is the integral of product of infinitesimal volume calculated?
The integral of product of infinitesimal volume is calculated by taking the limit of a Riemann sum, where the object is divided into smaller and smaller volumes, and then summing them up to find the total volume.
What are some real-world applications of the integral of product of infinitesimal volume?
The integral of product of infinitesimal volume is commonly used in fields such as physics, engineering, and architecture to accurately calculate volumes of objects such as fluids, electric fields, and building structures.
Are there any limitations to using the integral of product of infinitesimal volume?
One limitation of using the integral of product of infinitesimal volume is that it can be a complex and time-consuming process, especially for objects with irregular shapes. Additionally, it may not be applicable to all types of objects, such as objects with infinitely thin or infinitely small dimensions.
