Integral of tan^n (x), reduction fromula?
In summary, the reduction formula for tan^n x can be derived by recognizing that it is equivalent to integrating tan^(n-2)x times the derivative of tan^2x. To do so, use the identity tan^2x = sec^2x - 1 and integrate by parts.
David112234
105
[/B]
The reduction formula for tannx is a confusing matter for me,
First how do you derive it? Let's use tan3 as an example
Here in an integral calculator when it gets to tan4(x) it uses the reduction formula
BUT
When I ask it to integrate Tan3(x) the answer resembles nothing like the reduction formula.
So why do you use the reduction formula for tan^4 but not tan^3?
how do you derive the reduction formula using integration by parts?
2. Homework Equations
integration by parts ∫udv=uv-∫vdu
reduction formula ?
[/B]
∫tan^3 (x) dx
u= tan^3(x) dv=1
du= 3tan2(x)sec2(x)dx v = x
= xtan3 - ∫x3tan2(x)sec2(x)dx
again, ∫x3tan2(x)sec2(x)dx
u = x dv= tan3sec2
du = dx v =(tan ^4 )/¼
This is going no where to what the reduction formula is supposed to look like...
If you apply the reduction formula to ##\tan^3 x##, you get
$$\int \tan^3 x\,dx = \frac{\tan^2 x}{2} - \int \tan x\,dx.$$ You just have to recognize that since ##\sec^2 x = \tan^2 + 1##, the two results only differ by a constant.
To derive the reduction formula, you don't want to use integration by parts. Instead, write ##\tan^n x = \tan^{n-2} x \ \tan^2 x = (\tan^{n-2} x)(\sec^2 x-1)## and go from there.
FAQ: Integral of tan^n (x), reduction fromula?
1. What is the reduction formula for the integral of tan^n(x)?
The reduction formula for the integral of tan^n(x) is: ∫ tan^n(x) dx = (1/(n-1)) * tan^(n-1)(x) - ∫ tan^(n-2)(x) dx
2. How can the reduction formula be used to solve integrals of tan^n(x)?
The reduction formula can be used to solve integrals of tan^n(x) by reducing the power of tan(x) by 2 each time until the integral can be evaluated. This process is repeated until the integral can be evaluated in terms of known functions.
3. What is the general solution for an integral of tan^n(x) using the reduction formula?
The general solution for an integral of tan^n(x) using the reduction formula is: ∫ tan^n(x) dx = (1/(n-1)) * tan^(n-1)(x) - (1/(n-3)) * tan^(n-3)(x) + (1/(n-5)) * tan^(n-5)(x) + ... + C, where C is the constant of integration.
4. Are there any restrictions on the values of n for which the reduction formula can be used?
Yes, there are restrictions on the values of n for which the reduction formula can be used. The reduction formula can only be used for n > 1 and n is not equal to 0 or 1. If n is equal to 0 or 1, the integral can be evaluated using basic trigonometric identities.
5. Can the reduction formula be used for other trigonometric functions?
No, the reduction formula is specific to the integral of tan^n(x). It cannot be used for other trigonometric functions such as sin(x) or cos(x). Each trigonometric function has its own specific reduction formula for integration.
