Cistra
- 5
This has been driving me insane, and I'm sure it's something mind-boggling obvious but I can't seem to find it. I'll go through the work through here, I'm trying to prove that
[tex]\int_0^1{x^xdx}=\sum_{n=1}^{\infty}\frac{(-1)^{n+1}}{n^n}[/tex].
2. The attempt at a solution
Basically I'm having a negative somewhere that I'm not accounting for in my derivation of this. I'll just go through what I do step by step here until where I'm positive my error occurs...
[tex]\int_0^1{x^xdx}=\int_0^1{e^{xln(x)}dx}[/tex]
[tex]e^{xln(x)}dx=\sum_{n=0}^{\infty}\frac{1}{n!}x^nln^n(x)[/tex]
[tex]\sum_{n=0}^{\infty}\frac{1}{n!}\int_0^1x^nln^n(x)dx[/tex] and then I made the substitution [tex]u=-ln(x)[/tex] or [tex]e^{-u}=x,dx=-e^{-u}du[/tex] and I get after changing the bounds of integration
[tex](-1)^{n+1}{\int_0^{\infty}e^{-u(n+1)}u^ndu[/tex]
Here's the problem, I'm supposed to get [tex](-1)^n[/tex] as the constant in the integrand at this point but I can't get that extra -1 to go away. Ignoring that constant the rest of the proof goes out without a hitch, just using the Gamma function etc. but I can't make this silly negative go away! Can anyone see my mistake? =(
Thank you!
*Edit: The rest of the derivation from the last step. I made another substitution [tex]v=u(n+1),du=dv/(n+1)[/tex] and then I get
[tex]\frac{(-1)^{n+1}}{n+1}\int_0^{\infty}e^{-v}\left(\frac{v}{n+1}\right)^ndv=\frac{(-1)^{n+1}}{(n+1)^{n+1}}\int_0^{\infty}e^{-v}v^{n}dv[/tex].
That last formula is the one for [tex]\Gamma(n+1)=n![/tex] so then I get after substituting back into the sum,
[tex]\sum_{n=0}^{\infty}\frac{n!}{n!}\frac{(-1)^{n+1}}{(n+1)^{n+1}}=\sum_{n=0}^{\infty}\frac{(-1)^{n+1}}{(n+1)^{n+1}}[/tex].
Now I do make that substitution into the sum, setting [tex]n+1=k[/tex] I get
[tex]\int_0^1x^xdx=\sum_{k=1}^{\infty}\frac{(-1)^k}{k^k}[/tex]. The problem is that I'm supposed to get [tex](-1)^{k+1}[/tex] in that final sum rather than [tex](-1)^k[/tex].
