Integral Problem: Solve $\int\sqrt{\frac{1+t^{2}}{1-t^{2}}}\,dt$
  • Thread starter footmath
  • Tags
    Integral
In summary, the conversation is about solving the integral $ \int\sqrt{\frac{1+t^{2}}{1-t^{2}}}\,dt $, which cannot be done using elementary functions. The suggestion is to use Elliptic functions, which involves substituting t=sin(u) and dt = cos(u) du. The integral can then be written in the form $ \int \sqrt{1 + sin(\theta)^2} d\theta $ and by setting m=-1, it can be solved using the Elliptic Integral of the Second Kind. The person requesting help is having trouble solving the integral $ \int\sqrt{1+\sin^{2}x}\,dx $ and is asking for
footmath
hello.please solve this integral:
It cannot be done in terms of so-called "elementary" functions (powers, roots, trig functions, inverse trigs, logs, exponentials, etc.). Have you heard of Elliptic functions?
RGV
I have heard the Elliptic function .
please explain to solve this integral.
Let t=sin(u) and then dt = cos(u) du. Substitute those in for every t and dt you find. Some stuff should cancel out, and what you have left is very close to the definition of the elliptic function (of the second kind), given below.
[tex]E(\phi, m) = \int_0^\phi \sqrt{1 - m sin^2(\theta)} d\theta[/tex]
You just need to pick the right value for m.
this problem at the beginning was: int_(sinx)^1/2 which transformed to $ A=\int\sqrt{1+\sin^{2}x}\,dx $ -\int_1/{1+\sin^{2}x} and then transformed to $ \int\sqrt{\frac{1+t^{2}}{1-t^{2}}}\,dt $
The form you'll want it in is [itex]\int \sqrt{1 + sin(\theta)^2} d\theta[/itex]. Then, setting m=-1, you'll be able to put it in terms of the Elliptic Integral of the Second Kind.
would you please explain the solution of elliptic integral
I just did. In post 4, set m=-1 and see what integral you get. It's strikingly similar to the integral you're trying to solve.
Thank you but I can not solve this integral:$ A=\int\sqrt{1+\sin^{2}x}\,dx $
please explain about solution .
FAQ: Integral Problem: Solve $\int\sqrt{\frac{1+t^{2}}{1-t^{2}}}\,dt$
What is the Integral Problem?
The integral problem is a mathematical problem that involves finding the integral, or antiderivative, of a given function. It is the reverse process of differentiation, where the derivative of a function is found.
What is the given function in this integral problem?
The given function in this integral problem is √[(1+t²)/(1-t²)]. This function is known as a rational function, as it is a ratio of two polynomial expressions.
What is the general approach to solving this integral problem?
The general approach to solving this integral problem is to first simplify the given function by using algebraic techniques. Then, make a substitution to transform the function into a simpler form that can be integrated using known techniques. Finally, evaluate the integral and add the constant of integration.
What is the substitution used in solving this integral problem?
The substitution used in solving this integral problem is tanθ = t. This substitution is commonly used for integrals involving square roots of rational functions, as it helps to simplify the integral into one that can be solved using trigonometric identities.
What are some tips for solving this integral problem?
Some tips for solving this integral problem include: carefully choosing the substitution to simplify the given function, using trigonometric identities to simplify the integral, and double-checking your answer by differentiating the result to ensure it is correct.
