Integral Relation: $|a| > |b|$
In summary, an integral relation is a mathematical relationship between two variables that involves integration. The absolute value symbol in an integral relation represents the distance of a variable from 0, showing its magnitude without regard for its sign. When the absolute value of one variable is greater than another, it means that the area under the curve of the first variable is larger, indicating a greater magnitude. To solve an integral relation with this condition, integration techniques such as u-substitution or integration by parts are used, with appropriate limits of integration set based on the condition. This type of integral relation is commonly used in physics, engineering, economics, and finance to solve problems involving continuous functions.
polygamma
229
Show that for $|a| > |b| $,
$$\int_{0}^{\infty} \frac{\sinh bx}{\cosh ax + \cosh bx} \ dx = 2 \ln 2 \ \frac{b}{a^{2}-b^{2}} .$$
Mathematics news on Phys.org
Hint:
Show that for $a > b$, $$2 \sum_{n=1}^{\infty} (-1)^{n-1} \sinh (bnx) e^{-anx} = \frac{\sinh bx}{\cosh ax + \cosh bx} . $$
Here is my solution.
If $b = 0$, both sides of the equation are zero. So assume $|a| > |b| > 0$. By rescaling, the integral can be written $\int_ 0^\infty I(u; x)\, \frac{dx}{b}$ where
$\displaystyle I(u; x) = \frac{\sinh{x}}{\cosh{u x} + \cosh{x}}$
and $u = \frac{a}{b}$. Since the hyperbolic cosine is even, the value of the integral is unchanged when $u$ is replaced by $-u$. So we may assume, without loss of generality, that $u > 1$. Using the identity
$\displaystyle \cosh{ux} + \cosh{x} = \frac{e^{-ux}}{2}(e^{(u+1) x} + 1)(e^{(u-1) x} + 1)$
we obtain
$\displaystyle I(u; x) = \frac{e^{(u+1)x} - e^{(u-1) x}}{(e^{(u+1)x} + 1)(e^{(u-1) x} + 1)} = \frac{1}{e^{(u-1) x} + 1} - \frac{1}{e^{(u+1) x} + 1}$.
Since $u - 1$ and $ u + 1$ are positive, the last expression can written as the series
$\displaystyle \sum_{n = 1}^\infty (-1)^{n-1} (e^{-n (u-1) x} - e^{-n (u+1) x})$.
For $T > 0$,
$\displaystyle \sum_ {n = 1}^\infty (-1)^{n-1} \int_ T^\infty (e^{-n (u-1) x} - e^{-n (u+1)})\, dx$
$\displaystyle = \sum_{n = 1}^\infty \frac{(-1)^{n-1}{n}\left(\frac{e^{-(u-1) x}{u-1} - \frac{e^{-(u+1) x}{u+1}\right)$
$\displaystyle = \frac{\ln(1+e^{-(u-1) T})}{u-1} - \frac{\ln(1+e^{-(u+1)T})}{u+1}$,
which tends to zero as $T \to \infty$. Thus
$\displaystyle \int_0^\infty I(u; x)\, \frac{dx}{b} = \sum_{n = 1}^\infty (-1)^{n-1} \int_ 0^\infty (e^{-n (u-1)x} - e^{-n (u+1) x})\, \frac{dx}{b}\quad (*)$.
Since the integrals in (*) converge to $\frac{1}{n}\left(\frac{1}{u-1} - \frac{1}{u+1}\right)$, we deduce
$\displaystyle \int_ 0^\infty I(u; x)\, \frac{dx}{b} = \sum_{n = 1}^\infty \frac{(-1)^{n-1}}{n}\left(\frac{1}{u-1} - \frac{1}{u+1}\right) = \frac{2 \ln{2}}{b (u^2-1)} = \frac{2b\ln{2}}{a^2-b^2}$.
FAQ: Integral Relation: $|a| > |b|$
What is an integral relation?
An integral relation is a mathematical relationship between two variables that involves integration, or finding the area under a curve. It is commonly used in calculus to solve problems involving continuous functions.
What does the absolute value symbol mean in an integral relation?
The absolute value symbol, denoted by "|" around a variable, represents the distance of that variable from 0. In other words, it shows the magnitude or size of the variable without any regard for its sign (positive or negative).
What does it mean when the absolute value of one variable is greater than the absolute value of another in an integral relation?
When the absolute value of one variable is greater than the absolute value of another, it means that the area under the curve of the first variable is larger than the area under the curve of the second variable. This can also be interpreted as the magnitude of the first variable being greater than the magnitude of the second variable.
How do you solve an integral relation with the condition |a| > |b|?
To solve an integral relation with this condition, you will need to use integration techniques such as u-substitution or integration by parts. You will also need to set up the integral with the appropriate limits of integration based on the given condition.
In what real-world scenarios is the integral relation |a| > |b| commonly used?
This type of integral relation is commonly used in physics and engineering problems involving motion, such as calculating displacement, velocity, or acceleration. It is also used in economics to analyze supply and demand curves, as well as in finance to calculate the net present value of cash flows.
10K
