Integral substitution for a polynomial function
In summary, the conversation discusses making a substitution for the given integral and the corresponding changes in the limits. The final result is shown to be equivalent to $-\dfrac12\int_{-1}^3u^6\,du$.
karush
MHB
3,269
W.8.1.18
$$\int_{-1}^{1} \left(x^4-2x\right)^6\left(2x^3-1\right)\,dx $$
$u=x^4-2x$ $du=4x^3-2 dx =2(2 x^3-1) dx$
$$\frac{1}{2}\int_{-1}^{1} u^6\,du $$
Is this ok
karush said:
W.8.1.18
Is this ok
You forgot to change the limits.
If $u = x^4-2x$ then what's $u$ when $x = -1$ and when $x = 1$?
not sure what you mean, should $u$ be something else?
No, what you have done is correct. However, the limits should have changed. You're integrating the first integral between $x=-1$ and $x=1$. When you make the sub $u = x^4-2x $ your limits change! So $u = x^4-2x$ and when $x = -1$ you have $u = (-1)^4-2(-1) = 1+2 = 3$ and when $x = 1$ you have $u = (1)^4-2(1) = 1-2 = -1$. So you should have got:$$\displaystyle \frac{1}{2} \int_3^{-1} u^6 \,du$$
... which is equivalent to
\(\displaystyle -\dfrac12\int_{-1}^3u^6\,du\).
FAQ: Integral substitution for a polynomial function
What is integral substitution?
Integral substitution, also known as u-substitution, is a method used to simplify and solve integrals that involve a function within another function. It involves replacing the inner function with a new variable, u, to make the integral easier to solve.
Why is integral substitution useful?
Integral substitution is useful because it allows us to solve complex integrals that would otherwise be difficult or impossible to solve using other methods. It also helps to make the integration process more efficient and organized.
How do you know when to use integral substitution?
You can use integral substitution when you have an integral that involves a function within another function, and the derivative of the inner function is also present in the integral. This method is particularly useful when the integral involves trigonometric functions, exponential functions, and logarithmic functions.
What are the steps for using integral substitution?
The steps for using integral substitution are as follows:
  1. Identify the inner function and its derivative in the integral.
  2. Let u be the inner function and rewrite the integral in terms of u.
  3. Find the derivative of u and substitute it into the integral.
  4. Solve the resulting integral in terms of u.
  5. Substitute back in the original variable, x, to get the final solution.
What are some common mistakes to avoid when using integral substitution?
Some common mistakes to avoid when using integral substitution include forgetting to substitute the derivative of u back into the integral, using the wrong substitution for u, and not properly adjusting the limits of integration when substituting back in the original variable. It's important to carefully follow the steps and double check your work to avoid these errors.
