Integrals: #1 Help with fraction #2 Moment of inertia
In summary, the conversation discusses two homework problems, 25-2-EX9 and 26-5-9, and their solutions. In the first problem, the time rate of change of displacement of a robot arm is given and the task is to find the expression for displacement as a function of time. In the second problem, the task is to find the moment of inertia of a plate using an integral formula. The poster also asks for clarification on a step in the solution to problem 25-2-EX9 and for help in finding the error in their solution for problem 26-5-9.
togo
106
25-2-EX9
The time rate of change of the displacement (velocity) of a robot arm is ds/dt = 8t/(t^2 + 4)^2. Find the expression for the displacement as a function of time if s = -1 m when t = 0 s.
26-5-9
Find the moment of inertia of a plate covering the first-quadrant region bounded by [itex]y^2 = x, x = 9[/itex] and the x-axis with respect to x-axis.
25-2-EX9 unknown
26-5-9 [itex]Ix =k \int_c^d y^2(x_2 - x_1)dy[/itex]
25-2-EX9
This is a book example, so the solution is here. I am hung up on one step though.
[itex]\int ds = \int \frac{8tdt}{(t^2 + 4)^2} = 4 \int (t^2 + 4)^{-2}(2t dt)[/itex]
This next step throws me off. What happened to [itex](2t dt)[/itex]??
it just disappears. Can someone explain? Thanks.
[itex]s = 4(\frac{1}{-1})(t^2 + 4)^{-1} + C[/itex]
26-5-9
[itex]9ky^2dx = 9kx = 9k\frac{1}{2}x^2[/itex]
[itex]4.5x^2 = 4.5 * 3^2[/itex]
[itex]4.5*9 = 40.5[/itex]However, the answer is [itex]\frac{162}{5}k[/itex]
so where'd I go wrong? thanks.
togo said:
25-2-EX9
U-substitution was used without really showing it. Try letting u = t2+4 and rewrite the integral in terms of u and see what happens.
which formula would that be?
any suggestions?
Problem with derivative
accidental post.
FAQ: Integrals: #1 Help with fraction #2 Moment of inertia
#1 What is a fraction?
A fraction is a numerical quantity that represents a part of a whole. It is typically written in the form of a numerator over a denominator, such as 1/2 or 3/4.
#2 How do I solve integrals involving fractions?
To solve integrals involving fractions, you can use the method of partial fractions, which involves breaking the fraction into smaller, simpler fractions. You can then integrate each smaller fraction separately.
#3 What is a moment of inertia?
Moment of inertia is a measure of an object's resistance to changes in rotational motion. It is dependent on the mass and distribution of mass of an object.
#4 How do I calculate moment of inertia?
The formula for moment of inertia depends on the shape of the object. For example, for a point mass, the moment of inertia is equal to the mass multiplied by the square of the distance from the axis of rotation. For more complex shapes, you can use the parallel axis theorem or the perpendicular axis theorem to calculate moment of inertia.
#5 How is moment of inertia used in real life?
Moment of inertia is used in many real-life applications, such as designing structures and machines that need to rotate or maintain balance. It is also used in sports, such as figure skating and gymnastics, where the distribution of an athlete's mass affects their ability to perform certain movements. Additionally, moment of inertia is used in physics to understand the behavior of rotating objects.
