Integrate $\frac{1}{\sqrt{(3-x)(x-4)}}$ to Get $-\pi$
  • MHB
  • Thread starter Sherlock1
  • Tags
    Integration
In summary, the conversation discusses the integral $\displaystyle I = \int_{3}^{4}\frac{1}{\sqrt{(3-x)(x-4)}}\;{dx}$ and how it can be shown to be equal to $\pi$. It is suggested to let $t = 3-x$ and use the beta function to solve the integral. However, Wolfram gives a different answer for the second integral, $\displaystyle I = -\int_{0}^{-1}t^{-\frac{1}{2}}(-1-t)^{-\frac{1}{2}}.$ The conversation ends with a member expressing frustration and confusion about the different results obtained.
Sherlock1
38
Consider $\displaystyle I = \displaystyle \int_{3}^{4}\frac{1}{\sqrt{(3-x)(x-4)}}\;{dx}.$ It can be shown that this is $\pi$.
Let $t = 3-x$ for the integral and you get $\displaystyle I = -\int_{0}^{-1}t^{-\frac{1}{2}}(-1-t)^{-\frac{1}{2}}.$
However, the latter integral is equal to $-\pi$. Where is the negative from?
Re: Something really weird
Sherlock said:
Consider $\displaystyle I = \int_{3}^{4}(3-x)^{-\frac{1}{2}}(x-4)^{ - \frac{1}{2}}\;{dx}.$ It can be shown that this is $\pi$.
Hi Sherlock, :)
Both integrals should be equal to \(-\pi\). Can you write down your solution for the first integral, maybe you are missing a minus sign somewhere.
>>Integral 1<<
>>Integral 2<<
Kind Regards,
Sudharaka.
Sudharaka said:
Hi Sherlock, :)
>>Integral 1<<
>>Integral 2<<
Kind Regards,
Sudharaka.
Hello, Sudharaka. I did plug that in Wolfram but it gave me this! (Giggle)
I don't understand what is happening with wolfram, but you can solve this integral using the Beta function.
\[I = \int_{3}^{4}(3-x)^{-\frac{1}{2}}(x-4)^{ - \frac{1}{2}}\;{dx}\]
Substitute, \(t=x-3\) and we get,
\begin{eqnarray}
I &=& \int_{3}^{4}(3-x)^{-\frac{1}{2}}(x-4)^{ - \frac{1}{2}}\;{dx}\\
&=&-\int_{0}^{1}t^{-\frac{1}{2}}(1-t)^{-\frac{1}{2}}\,dt\\
&=&-\beta\left(\frac{1}{2},\frac{1}{2}\right)\\
\end{eqnarray}
Since, \(\beta(x,y)=\dfrac{\Gamma(x)\,\Gamma(y)}{\Gamma(x+y)}\!\) we have,
\[I=-\frac{\Gamma\left(\frac{1}{2}\right)\,\Gamma\left(\frac{1}{2}\right)}{\Gamma(1)}=-\pi\]
That's how I did it as well. But I still don't understand the negative anomaly.
Apparently $\displaystyle I = \int_{3}^{4}\bigg[(3-x)(x-4)\bigg]^{-\frac{1}{2}}\;{dx} = -\int_{3}^{4}(3-x)^{-\frac{1}{2}}(x-4)^{ - \frac{1}{2}}\;{dx}?$
No. Refer my previous post and you'll and see that it's equal to \(-\pi\).
Can you please show how you calculated the second integral?
Sorry, the first post should have read:
Sherlock said:
Consider $\displaystyle \int_{3}^{4}\bigg[(3-x)(x-4)\bigg]^{-\frac{1}{2}}\;{dx}.$ It can be shown that this is $\pi$.
Wolfram agrees that the first integral is $\pi$ (see my link above).
But as you have seen the second integral is $-\pi$. Why is this?
I don't know why wolfram gives different answers when the problem is stated in different ways. Maybe some other member will be able to enlighten you as to why wolfram behaves that way. However we have obtained that,
\[\int_{3}^{4}(3-x)^{-\frac{1}{2}}(x-4)^{ - \frac{1}{2}}\;{dx}=-\int_{0}^{-1}t^{-\frac{1}{2}}(-1-t)^{-\frac{1}{2}}\,dt=-\pi\]
You still don't get me. Let me illustrate what I mean by way of a solution:
Let $x = \frac{7}{2}+t$ then we have:$\displaystyle \begin{aligned} I & = \int_{3}^{4}\frac{1}{\sqrt{(3-x)(x-4)}}\;{dx} = \int_{-\frac{1}{2}}^{\frac{1}{2}} \frac{1}{\sqrt{(\frac{1}{2})^2-t^2}}\;{dt} = 2 \int_{0}^{\frac{1}{2}}\frac{1}{\sqrt{(\frac{1}{2})^2-t^2}}\;{dt} \\& = 2\sin^{-1}(2t)\bigg|_{0}^{1/2} = 2\sin^{-1}(1)-2\sin^{-1}(0) = \pi. \end{aligned}$
But if we do it the beta function way like you have done, we get $-\pi$.
I hope you understand what I mean now. This is driving me insane!
Here is the full version of Mathematica's solution.
https://www.physicsforums.com/attachments/460
What does it give when you enter $\displaystyle \int_{3}^{4}\frac{1}{\sqrt{(3-x)(x-4)}}\;{dx}$ (both terms under the radical), though? Thanks.
For that integral it, gave me pi whereas the other two gave the set containing -pi.
The notation $\sqrt x$ (for a positive number $x$) by definition means the positive square root. If you integrate a positive function over a (positively oriented) interval, you can never get a negative answer. So if the answer comes out as $-\pi$, you know that something has gone wrong somewhere.
In this case, something is odd about the integral $-\displaystyle\int_{0}^{-1}t^{-\frac{1}{2}}(-1-t)^{-\frac{1}{2}}\,dt$, because $t$ and $-1-t$ are both negative when $-1<t<0$, and therefore do not have real square roots. But their product is positive, so you can write the integral as $-\displaystyle\int_{0}^{-1}\bigl(t(-1-t)\bigr)^{-\frac{1}{2}}\,dt = \int_{-1}^{0}\bigl(t(-1-t)\bigr)^{-\frac{1}{2}}\,dt$. This should come out as $+\pi$.
Thanks. Could you explain bit more as to how inverting the limits voids the negative, please? I can't see it.
I know it cancels the immediate one before the integral, but in the end we still end-up with $-\pi$? Thanks!
As far as I can see, the mistake comes from mishandling the expression $1/\sqrt{(3-x)(x-4)}$. If you write it as $(3-x)^{-1/2}(x-4)^{-1/2}$, then (in the interval $3<x<4$ over which you are integrating) that is the product of two complex numbers. Both $3-x$ and $x-4$ are negative in that interval, so each of them has two purely-imaginary square roots and there is no reliable way to select one of those roots rather than the other.
What you should do, if you want to transform the integral into a beta-function form, is to re-write $1/\sqrt{(3-x)(x-4)}$ as $1/\sqrt{(x-3)(4-x)} = (x-3)^{-1/2}(4-x)^{-1/2}$. That is now the product of two positive numbers and you can make the substitution $t=x-3$ to get the integral in the form $\displaystyle\int_0^1t^{-1/2}(1-t)^{-1/2}\,dt = \beta(1/2,1/2).$
I have fallen into >>this trap<< a couple of times yet never learns form the mistake. (Headbang)
@Opalg: Thank you very much for your valuable insight into this problem. :)
FAQ: Integrate $\frac{1}{\sqrt{(3-x)(x-4)}}$ to Get $-\pi$
What does it mean to integrate a function?
Integrating a function is the process of finding the area under the curve of the function. It is the reverse operation of differentiation, which is used to find the slope of a curve at a given point.
Why is the function $\frac{1}{\sqrt{(3-x)(x-4)}}$ integrated using the negative sign and $\pi$?
The negative sign indicates that the area under the curve is below the x-axis, and $\pi$ is used as a constant in the integration formula for this particular function.
Can the function $\frac{1}{\sqrt{(3-x)(x-4)}}$ be integrated using other methods besides using $\pi$?
Yes, there are other methods for integrating this function, such as using trigonometric substitutions or completing the square.
What is the significance of the limits of integration when integrating this function?
The limits of integration represent the interval over which we are finding the area under the curve. In this case, the limits are 3 and 4, which correspond to the roots of the function.
How is the integrated function used in real-world applications?
The integrated function can be used to solve problems related to finding the area of irregular shapes or calculating the work done by a variable force. It also has applications in physics, engineering, and economics.
