Integrate Plancks Function to find Stefans Law
In summary, the conversation discusses issues with the solution to a problem involving the series formula and integrals. The constants (KT/HC)^4 are used to find (lamda)^5 and the series formula 1/(1-epsilon) is applied to get x^3e^-nx. The conversation also touches on the derivatives involved and how to get the actual answer, which is found to be 6/a^4. The integration limits are then plugged in to find the answer to be (pi)^4/90.
DODGEVIPER13
672
See uploaded file
See Uploaded file
Ok problem 1 I have with the solution why is (KT/HC)^4 on the outside of the integral and why is it to the 4th power. I assume it is to find (lamda)^5 but I would think if that was the case it would be to the 5th power. My second issue is when I apply the series formula 1/(1-epsilon) and make it 1/(1-e^-x) I end up x^3e^-nx but it appears to be missing another e^(-x). Then they do this derivative deal and get 1/a but I think it should be -1/a(e^-ax). Anyways they continue on this path until they get 6/a^4 which is the answer to the series but why do they stop there I am confused . Then how did the get (pi)^4/90 in there and how do I get the actual answer? Sorry I know its a ton of questions but I am hopelessly lost.
They essentially do [itex]u = a\lambda[/itex], where [itex]a[/itex] is that mix of constants. Express [itex]\lambda = u/a[/itex] and [itex]d\lambda = du/a[/itex], and see what you get, then convert a to that constant mix.
No, it's not. Observe that [itex]\frac 1 {1 - e^{-x}} = 1 + e^{-x} + e^{-2x} + ... [/itex]. That is, the first term of that is just 1. But when they integrate, the first term is [itex]e^{-x}[/itex], because they multiply the series by [itex]e^{-x}[/itex]
This is the indefinite integral. Now plug in the integration limits - what do you get?
They have found that all the integrals they need to compute are [itex]\frac 6 {n^4}[/itex].
[itex]\sum_{n = 0}^{\infty}\frac 1 {n^4} = \frac {\pi^4} {90}[/itex]. This is known because on the left you haven the value of [itex]\zeta[/itex]-function at 4, which can be computed in a number of ways.
Sweet thanks man you cleared up all my issues I get it now.
FAQ: Integrate Plancks Function to find Stefans Law
1. What is Planck's function?
Planck's function, also known as the Planck's law or blackbody radiation law, is a mathematical formula that describes the spectral energy density radiated by a blackbody at a given temperature.
2. What is Stefan's law?
Stefan's law, also known as the Stefan-Boltzmann law, is a physical law that states the total energy radiated by a blackbody is proportional to the fourth power of its absolute temperature.
3. How do you integrate Planck's function to find Stefan's law?
To integrate Planck's function, you need to use calculus and the fundamental theorem of calculus. This involves taking the integral of the function over a given range of wavelengths or frequencies, depending on the form of the function used. The result of the integration will be the Stefan's law, which gives the total energy emitted by a blackbody at a given temperature.
4. What are some applications of integrating Planck's function to find Stefan's law?
Integrating Planck's function to find Stefan's law has many practical applications, such as in astrophysics, where it is used to study the radiation emitted by stars and other celestial bodies. It is also used in the development of thermal imaging devices, as well as in the design of energy-efficient buildings and solar panels.
5. Is integrating Planck's function to find Stefan's law a complicated process?
The process of integrating Planck's function to find Stefan's law may seem complicated due to the use of calculus, but it is a well-established and straightforward mathematical procedure. With the help of computational tools and software, it can be easily performed and applied in various fields of science and engineering.
