Integrate: (x^2 + 4)/ (x^2+5x-6) dx
  • Thread starter Thread starter beaf123
    Dx Integrate
The discussion revolves around integrating the function (x + 4)/(x^2 + 5x - 6) using partial fractions. The correct factorization of the denominator is identified as (x - 1)(x + 6), leading to the setup of A and B for the partial fractions. The values of A and B are calculated, but there are errors in the initial solutions presented. The final integration results in a logarithmic expression that can be simplified using logarithmic properties to match the provided solution. The importance of correctly applying these properties and the constant of integration is emphasized.
beaf123
"Express the integrand (what does "integrand" mean?) as a sum of partial fractions and evaluate the integrals.
∫(x + 4)/ (x^2+5x-6) dx
x^2+5x-6 = (x-1)(x+6)
Gives:
∫ A/(x-1) + B/(x+6) dx
Findig A and B:
A(x+6) + B(x-1)
A+B=1
6A-B =4
A= 5/7
B= - (2/7)Then:
∫ (5/7) (1/x-1) dx +∫ - (3/7)(1/x+6) dx
Gives I think:
5/7ln(x-1) -2/7ln(x+6)But its wrong accordng to the solution. I can post the solution here if you want me to:
Gives:
Findig A and B:
A(x+6) + B(x-1)
A+B=1
6A-B =4
A= 5/7
B= - (3/7)Then:
Gives I think:
5/7ln(x-1) -3/7ln(x+6)But its wrong accordng to the solution. I can post the solution here if you want me to:
The integrand is the expression being integrated, in this case, the rational function \frac{x+4}{x^2+5x-6}
How did you get A+B=1 ?
Okey, thanks.
A(x+6) + B(x-1) = x+4
Ax +Bx +6A -B = x+4
Ax + Bx = xA+B =1
beaf123 said:
Okey, thanks.
Ax +Bx +6A -B = x+4
Ax + Bx = x
A+B =1
Oh I see, you were comparing coefficients :smile:
Sorry I didn't spot your error before, but you incorrectly solved the simultaneous equations in A and B. 1 - 5/7 = 2/7
Oh, I changed it now. It is correct so far, but I don't understand how they get 5/7ln(x-1) -2/7ln(x+6) to become ( from solution): (1/7)ln[(x+6)^2(x-1)^5] + C
That should be
5/7ln(x-1) + 2/7ln(x+6)​
Then use properties of logarithms to get the desired result.
Of course the given answer includes the constant of integration.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
