Integrating a theta function/2d probability density function
In summary: Now for the second part I'm thinking that I've got to show that the following statement is true$$\int_{\phi=0}^{2\pi} \int_{r=r_{min}}^{r_{max}} \rho(r,\theta;t)rdrd\theta =1$$where rmaxand rmin are the maximum and minimum radii of the region the gas is in at that time which I think is a circle for a>vt and a doughnut shape for a<vt by thinking of the entire region as a series of circles of the same radius with centers moving away from the origin at the same speed in every possible direction.I think you mean ##\theta=0## on the lower limit
Thimble
A two-dimensional circular region of radius a has a gas of particles with uniform
density all traveling at the same speed but with random directions. The wall of the
chamber is suddenly taken away and the probability density of the gas cloud subsequently
satisfies
$$ \rho(r,\theta;t)=\frac{1}{\pi a^2}\int_0^{2\pi} \frac{d\phi}{2\pi} \Theta[a^2-r^2-(vt)^2+2rvtcos(\theta-\phi)]$$
where (r, θ) are the polar-coordinates of the point at issue, t is the time, v is the velocity
of the gas,Φ is the random orientation and Θ[x] vanishes if x is negative and is unity
if x is positive. Employing the equations below show that for each Φ and t the region mapped out by Θ is a circle and hence that the density is normalised.
$$x=rcos(\theta)$$
$$y=rsin(\theta)$$
$$d_x=vtcos(\phi)$$
$$d_y=vtsin(\phi)$$
Firstly I rearranged the theta expression to get
$$\Theta[a^2-(x-d_x)^2-(y-d_y)^2]$$ which I think satisfies the first part of the question with each Φ and t mapping out a circle with radius a and centre (dx,dy)
where rmaxand rmin
The stumbling block I'm having is trying to integrate this theta function. My attempt at it was just treating the theta function as one as for all Φ there are points where the expression inside the theta is greater than zero and thus Θ=1, but this gives a constant probability density which doesn't make sense to me as the area over which the gas is in is expanding so the probability density must surely decrease. I've never come across this type of function before and all the examples I've seen on the internet for them all seem to be in one variable rather than 4 (r,θ,t and Φ)so could anyone point me towards any guidance on how to integrate these types of functions? Thanks in advance for any help.
EDIT: Changed upper limit in the first integral to 2π.
I think you mean ##\theta=0## on the lower limit, right? Use 0 and ##\infty## for the limits of the integral over ##r##. For a fixed ##\phi## and ##t##, the ##\Theta## function will only be equal to 1 when ##r## and ##\theta## correspond to a point inside the circle of radius ##a##, so you can write down what the result of the double integral should be. Then you still have the integral over ##\phi## to take care of.
Yes I should have θ=0 on the bottom limit. I don't see why we use 0 and ∞ as the limits for r, surely the integral at r=∞ is 0 and after a certain time the integral at r=0 will be 0 as well (As Θ will be zero at these values)? Also I'm still struggling to figure out how to obtain what ρ(r,θ;t) is to be able to do the double integral.
Generally, to show a probability density is normalized, you integrate over all space and show the result is equal to 1. You can certainly change the limits to omit the regions where the integrand vanishes, but why bother? It doesn't change the result and is an unnecessary complication.
You've been given ##\rho##. What's there to obtain?
I've been given ρ in terms of that integral of Θ that I'm not sure how to calculate. Without having the actual value for ρ rather than in terms of that definite integral I'm not sure how to show that the integral of ρ is equal to 1, unless I'm missing something obvious.
Keep ##\rho## in terms of the integral of ##\Theta##, plug it into the double integral, and then change the order of integration so you integrate over ##\phi## last.
Ah, that makes sense. Just two more quick questions if you don't mind. As r would be treated as a constant in an integral with respect to Φ can i just take it inside the integral as follows to get
$$\int_{\theta=0}^{2\pi}\ \int_{r=0}^\infty \int_{\phi=0}^{2\pi} \frac{r \Theta[a^2-r^2-(vt)^2+2rvtcos(\theta-\phi)]}{2\pi^2a^2} d\phi dr d\theta$$
I'd then obviously take out the constants to make it look neater. Then am i able to just shift around the order that the integrals are performed in with no further changes? I've seen some places saying I can and some that I can't. Sorry for having so many questions and thanks for your help so far.
Related to Integrating a theta function/2d probability density function
What is a theta function/2d probability density function?
A theta function/2d probability density function is a mathematical function used to describe the probability distribution of a continuous random variable. It maps the possible outcomes of a variable to their corresponding probabilities, and is often represented graphically as a curve.
What is the purpose of integrating a theta function/2d probability density function?
The purpose of integrating a theta function/2d probability density function is to calculate the total probability of a certain range of values for a continuous random variable. This can be useful in various statistical and scientific analyses, such as determining the likelihood of an event occurring or estimating the expected value of a variable.
How do you integrate a theta function/2d probability density function?
The process of integrating a theta function/2d probability density function depends on the specific function and the range of values being integrated. In general, the integral can be solved using techniques such as substitution, integration by parts, or numerical methods such as Simpson's rule. The exact method will vary depending on the complexity of the function and the desired level of precision.
What is the difference between integrating a theta function and a 2d probability density function?
The main difference between integrating a theta function and a 2d probability density function is the number of variables involved. A theta function typically involves only one variable, while a 2d probability density function involves two variables (usually representing two different random variables). The process of integration will also differ, as a 2d probability density function will require a double integral to account for both variables.
What are some real-world applications of integrating a theta function/2d probability density function?
Integrating a theta function/2d probability density function has many practical applications in fields such as statistics, economics, physics, and engineering. Some examples include calculating the likelihood of an event occurring based on a continuous variable (e.g. the probability of a stock price reaching a certain value), estimating the expected value of a variable (e.g. the average rainfall in a certain area), and determining the probability of a certain outcome in a scientific experiment.
