Integrating an absolute function
In summary, an absolute function is a mathematical function that gives the distance of a number from zero and always returns positive values. Integrating an absolute function is important for solving real-world problems and involves breaking the function into two parts and combining the integrals for each part. Indefinite integration results in a general solution while definite integration gives a specific numerical value, and there are special cases when the function is piecewise-defined.
steve snash
50
⌠ | 10^(1/2)*(x^5)+(5*x^(1/5)) | dx
−1
once the absolute value is gone you can just integrate the function
how do you get rid of the absolute, and how do you then integrate it, do you use the product rule with 10^(1/2)*(x^5)
Notice the function inside the absolute value signs is an odd function and is positive if x>0. So its absolute value will be an even function. So double the integral from 0 to 1.
FAQ: Integrating an absolute function
What is an absolute function?
An absolute function, also known as an absolute value function, is a mathematical function that gives the distance of a number from zero. It always returns positive values, regardless of the input.
Why is integrating an absolute function important?
Integrating an absolute function can help solve many real-world problems, such as finding the total distance traveled by an object given its velocity function or calculating the net change in a quantity over a given interval.
What is the process for integrating an absolute function?
The process for integrating an absolute function involves breaking the function into two parts - one for positive values and one for negative values. Then, the integral of each part can be calculated separately using the appropriate integration technique. Finally, the two integrals are combined to get the overall solution.
What is the difference between indefinite and definite integration of an absolute function?
Indefinite integration of an absolute function results in a general solution, while definite integration gives a specific numerical value for the integral over a given interval. Indefinite integration involves adding a constant term to the solution, while definite integration does not.
Are there any special cases when integrating an absolute function?
Yes, there are some special cases when integrating an absolute function. One such case is when the function is piecewise-defined, meaning it has different definitions for different intervals. In this case, the integral must be calculated separately for each interval and then added together to get the overall solution.
