Integrating an inequality for two functions of the same variable
  • Thread starter member 731016
In summary, the article discusses the process of integrating an inequality that involves two functions of the same variable. It emphasizes the conditions under which the inequality holds true and provides methods for deriving results from the integration of these functions. The focus is on establishing relationships between the integrals of the functions and ensuring that the inequality remains valid throughout the integration process. Furthermore, it highlights applications in various mathematical contexts, illustrating the significance of these techniques in analysis and problem-solving.
member 731016
Please see below
Please see below
For this true or false problem,
The answer if false, however, I am confused by this result as my working shows that the is true.
My working is, integrating both sides of the inequality we get ##\int f'(x) dx> \int g'(x) dx## for all ##x \in (a,b)## which is the equivalent to ##f(x) > g(x)## for all ##x \in (a,b)##.
Does someone please know what I have done wrong?
Thanks!
Counterexample: ##f(x)=-e^{-x}## and ##g(x)=1##. Then for all ##x##: ##f'(x)>g'(x)## but ##f(x)<g(x)##.
  • Love
Likes member 731016
Thank you for your reply @renormalize!
Sorry I am tying to generalize this without considering specific counter examples. I am trying to consider the most general case, this is why I integrate.
Thanks!
But this single counterexample is sufficient to show that your "general case" cannot be proven. Hence statement 6 is False, with no further work needed.
  • Love
Likes member 731016
Thank you for your reply @renormalize !
Sorry I am still confused. I integrated the inequality and obeyed the laws of algebra and my integration still worked. I'm not sure what is going on, I think maybe the question is wrong.
Thanks!
Thanks!
You can take the counterexample and put it in your chain of arguments to see at which step it fails. You can also use - which is what I do first - the fundamental theorem of calculus, either for the entire interval ##(a,b)## or for ##(a,x).##
  • Love
Likes member 731016
Don't forget about that sneaky constant that you should add when you evaluate an antiderivative.
If ##f' > g'## on (a,b), then what can you say about comparing ##\int {f'} + c_1## to ##\int {g'} + c_2##?
In other words, does the slope of ##f## being larger mean that the value of ##f## will be larger? Compare f(x)=2x with g(x)=x+1000 on (0,1).
  • Love
Likes Mark44, member 731016 and fresh_42
That's why I like FTC as a first test. It forces you to use the constants and can help to see where a general argument might fail.
  • Love
Likes member 731016 and FactChecker
##\int (f-g)'>c> 0 ##
It would work if we had ##\int f'-g' =0 ##, with an equality at some value ##x,## so that ##f(x)=g(x)##, i.e., if they're equal at some point and grow at the same rate . Like Fact Checker mentioned, said, one just grows faster than the other, but you don't have additional knowledge of initial conditions. This is a sort of PDE without additional conditions and an inequality.
  • Love
The following inequality is true: if [itex]f(x) \leq g(x)[/itex] on [itex][a,b][/itex] then [tex]
\int_a^b f(x)\,dx \leq \int_a^b g(x)\,dx.[/tex] (We can replace the upper limits with an aarbitrary [itex]t \in [a,b][/itex].) Replacing [itex]f[/itex] and [itex]g[/itex] by derivatives and using the fundamental theorem, this implies [tex]
\forall x \in [a,b] : f'(x) \leq g'(x) \quad \Rightarrow \quad \forall x \in [a,b] : f(x) - f(a) \leq g(x) - g(a).[/tex] What this is saying is that if [itex]f[/itex] increases more slowly than [itex]g[/itex] and they start in the same place, then [itex]f[/itex] will be less than [itex]g[/itex].
  • Love
FAQ: Integrating an inequality for two functions of the same variable
What does it mean to integrate an inequality for two functions?
Integrating an inequality for two functions involves determining the integral of each function over a specified interval and comparing their results. If you have two functions, f(x) and g(x), and the inequality f(x) ≤ g(x) holds for all x in the interval, then the integral of f(x) over that interval will also be less than or equal to the integral of g(x).
How do you set up the integral for two functions in an inequality?
To set up the integral for two functions in an inequality, first ensure that the inequality f(x) ≤ g(x) is true for all x in the interval [a, b]. Then, you can express the integrals as follows: ∫[a to b] f(x) dx ≤ ∫[a to b] g(x) dx. This setup allows you to evaluate the area under each curve and compare the results.
Can the integral of an inequality be used to prove properties of functions?
Yes, the integral of an inequality can be used to prove various properties of functions, such as monotonicity or boundedness. For example, if you can establish that f(x) ≤ g(x) for all x and integrate both functions, the results can provide insights into the behavior of f(x) relative to g(x) over the interval.
What are some common techniques for integrating inequalities?
Common techniques for integrating inequalities include the use of the Fundamental Theorem of Calculus, comparison tests, and properties of definite integrals. Additionally, one may apply techniques such as substitution or integration by parts, depending on the complexity of the functions involved.
Are there any limitations when integrating inequalities for two functions?
Yes, there are limitations when integrating inequalities. The primary requirement is that the functions must be integrable over the interval in question. Furthermore, the inequality must hold true for all points in the interval. If either function has discontinuities or is not defined over the entire interval, the conclusions drawn from the integrals may not be valid.
