Integrating exponential functions
In summary, the integral $\int x (5^{-x^2})dx$ can be rewritten as $-\frac{1}{2}\int 5^{-x^2}(-2x)dx$. To derive the $\frac{1}{2}$ in front of the integral, we use the chain rule and the fact that $\frac{d}{dx} e^{-x^2\ln(5)}=-2x\ln(5) e^{-x^2\ln(5)}$. Thus, the final result is $-\frac{5^{-x^2}}{2\ln(5)}+C$.
karush
MHB
3,269
$\int x (5^{-x^2})dx= -\frac{1}{2} \int 5^{-x^{2}}(-2x)dx$
how is $\frac{1}{2}$ in front of the $\int$ derived
dx is missing !
5-x²=exp(-x²ln(5))
x²=t
x dx = dt/2
sorry i hit the save instead of preview thot I cud fix it before reply
I've done that before, and it is annoying! (Headbang)
\[\int x (5^{-x^2})dx= \int x e^{-x^2\ln(5)}dx\]
Now: \[\frac{d}{dx} e^{-x^2\ln(5)}=-2x\ln(5) e^{-x^2\ln(5)}\] so:
\[\begin{aligned}\int x (5^{-x^2})dx &=-\frac{1}{2\ln(5)}\int \frac{d}{dx} e^{-x^2\ln(5)} dx\\
&=-\frac{e^{-x^2\ln(5)}}{2\ln(5)}+ C \\ &=-\;\frac{5^{-x^2}}{2\ln(5)}+C \end{aligned} \]
CB
FAQ: Integrating exponential functions
What is an exponential function?
An exponential function is a mathematical function in the form of f(x) = ab^x, where a and b are constants and x is a variable. The variable, x, is typically in the exponent, giving rise to the name "exponential".
How do you integrate an exponential function?
To integrate an exponential function, you can use the power rule of integration, which states that the integral of x^n is (x^(n+1))/(n+1), where n is any real number. For an exponential function, this means that the integral of ab^x is (ab^x)/ln(b) + C, where C is the constant of integration.
What are some real-world applications of integrating exponential functions?
Integrating exponential functions can be used to model various natural phenomena, such as population growth, radioactive decay, and compound interest. It is also commonly used in physics, chemistry, and economics to describe rates of change.
Are there any special rules for integrating exponential functions?
One special rule for integrating exponential functions is the logarithmic integration rule, which states that the integral of e^x is ln(e^x) + C = x + C. This rule can be helpful in simplifying integrals of exponential functions with a base of e.
Can exponential functions be integrated using substitution?
Yes, exponential functions can be integrated using substitution. However, it may not always be the most efficient method. In some cases, using the power rule or logarithmic rule may be easier. It is important to consider the form of the function and choose the most appropriate integration technique.
