Integrating Factors for Solving Differential Equations
  • MHB
  • Thread starter kayella19
In summary, the differential equation is difficult to solve, but Dr. Agarwal provides a integrating factor that can be used to solve it.
kayella19
solve n(9m²+18m-mn²-n²)dm + m(9m+9mn-3n²-n³)dn = 0
Any thoughts on how to begin?
I have no any ideas. But in reference with Differential Equation 7th edition by rainville and bedient. It's under on ADDITIONAL TOPIC IN FIRST ORDER DIFF. EQUATION
I haven't solved this ODE, but I think I would first check for exactness. Is this an exact ODE?
This is an extremely annoying kind of differential equation, where you need an integrating factor not of the usual form. I have to admit that I cheated by using Wolfram|Alpha, which can find the solution. Here's a form of integrating factor that works:
$$\mu=e^{r\cdot n+s\cdot m},$$
with $r$ and $s$ constants to be determined.
Yes, I cannot find an integrating factor using the methods with which I am familiar. I also initially used W|A to find the solution, and at least you were able to determine the form of an integrating factor that works. (Yes)
Note: This was done by taking the solution given by W|A and essentially "working backwards."
We are given to solve:
\(\displaystyle n\left(9m^2+18m-n^2-mn^2\right)dm+m\left(9m+9mn-3n^2-n^3\right)dn=0\)
Arrange as:
\(\displaystyle \left(n(9m-n^2)+9mn+mn(9m-n^2)\right)dm+\left(m(9m-n^2)-2mn^2+mn(9m-n^2)\right)dn=0\)
Further arrange as:
\(\displaystyle dm\cdot n(9m-n^2)dm+m(9m-n^2)dn+mn\left(9dm-2ndn\right)+mn(9m-n^2)\left(dm+dn\right)=0\)
Looking at the last factor in the last rem on the LHS, we observe that an integrating factor is $\mu=e^{m+n}$:
\(\displaystyle dm\cdot n(9m-n^2)e^{m+n}+m\cdot dn\cdot(9m-n^2)e^{m+n}+mn\left(9\,dm-2n\,dn\right)e^{m+n}+mn(9m-n^2)e^{m+n}\left(dm+dn\right)=0\)
Or:
\(\displaystyle n(9m-n^2)e^{m+n}+m\d{n}{m}\cdot(9m-n^2)e^{m+n}+mn\left(9-2n\d{n}{m}\right)e^{m+n}+mn(9m-n^2)e^{m+n}\left(1+\d{n}{m}\right)=0\)
This can be written as:
\(\displaystyle \frac{d}{dm}\left(mn(9m-n^2)e^{m+n}\right)=0\)
Integrate w.r.t $m$:
\(\displaystyle \int \frac{d}{dm}\left(mn(9m-n^2)e^{m+n}\right)\,dm=0\int \,dm\)
And so the solution is given implicitly by:
\(\displaystyle mn(9m-n^2)e^{m+n}=c_1\)
Nice write up MarkFL. I konw Dr.Agarwal's book here gives some clues on the integrating factor for this particular problem. An Introduction to Ordinary Differential Equations | Ravi P. Agarwal | Springer He actually offers several generic integrating factors for different ODE's and this is one of the forms he provides with a very arbitrary proof.
I have worked with him on a couple research projects, and he offers a very good proof showing the first step solving by induction. He doesn't clearly state the n+1 case, but it does in fact admit an integrating factor of the form given above confirming the above calculations.
FAQ: Integrating Factors for Solving Differential Equations
What is the problem that needs to be solved?
The problem that needs to be solved is typically described as a complex mathematical or scientific puzzle that requires a high level of critical thinking and problem-solving skills.
Who is asking this question?
This question is usually asked by individuals or groups who have been presented with the problem and are seeking assistance in finding a solution.
What are the potential solutions to this problem?
There may be multiple potential solutions to the problem, and they may vary depending on the specific details and parameters of the problem. It is important to carefully consider all possible solutions and their potential effectiveness before choosing one to pursue.
What qualifications or skills are necessary to solve this problem?
Solving complex problems often requires a combination of technical knowledge, critical thinking skills, and creativity. Depending on the specific problem, expertise in a particular field or subject may also be necessary.
How long does it typically take to solve a problem like this?
The time it takes to solve a problem like this can vary greatly depending on its complexity and the skills and resources of the person or team attempting to solve it. Some problems may be solved relatively quickly, while others may require weeks, months, or even years of work.
11K
