btouellette
- 4
Integrate the monochromatic luminosity (of a blackbody model star) over all wavelengths to obtain an expression for the total luminosity. This is 3.14(a) from An Introduction to Modern Astrophysics 2e by Carroll and Ostlie.
## L_\lambda d\lambda = \frac{8 \pi^2 R^2 h c^2 / \lambda^5}{e^{h c / \lambda k T} - 1} d\lambda ##
## \int_0^\infty \frac{u^3}{e^u - 1} \, du = \frac{\pi^4}{15} ##
So we need to evaluate
## L = \int_0^\infty L_\lambda \, d\lambda = \int_0^\infty \frac{8 \pi^2 R^2 h c^2 / \lambda^5}{e^{h c / \lambda k T} - 1} \, d\lambda ##
## L = 8 \pi^2 R^2 h c^2 \int_0^\infty \frac{1}{\lambda^5 (e^{h c / \lambda k T} - 1)} \, d\lambda ##
Using u-substitution with
## u = \frac{hc}{\lambda k T} ##
## du = \frac{-hc}{\lambda^2 k T} d\lambda ##
results in
## L = 8 \pi^2 R^2 h c^2 \int_0^\infty \frac{1}{e^{h c / \lambda k T} - 1} \frac{1}{\lambda^5} \, d\lambda = 8 \pi^2 R^2 h c^2 \int_0^\infty \frac{1}{e^u - 1} \frac{u^3 k^3 T^3}{h^3 c^3} \frac{-k T}{h c} \, du ##
so that makes
## L = \frac{-8 \pi^2 R^2 k^4 T^4}{c^2 h^3} \int_0^\infty \frac{u^3}{e^u - 1} \, du ##
and using the definition of the definite integral from the givens we get
## L = \frac{-8 \pi^6 R^2 k^4 T^4}{15 c^2 h^3} ##
Everything here makes sense and is in agreement with the solution I've seen as well as the followup problems except for the negative factor. It also doesn't make much sense to have a negative luminosity in this context. I expect I've botched something small in the u-substitution but for the life of me I can't spot it.
