Integrating Rational Functions
In summary, the conversation discusses evaluating the integral of ∫\frac{dx}{x3 + 2x} using partial fraction decomposition. The coefficients A, B, and C are solved for and the final answer is determined to be \frac{1}{2}ln x - \frac{1}{4}ln(x2 + 2). The speaker is advised to check their answer for correctness by taking the derivative.
Mosaness
92
1. ∫[itex]\frac{dx}{x3 + 2x}[/itex]
We're suppose to evaluate the integral.
Use Partial Fraction Decomposition:
[itex]\frac{1}{x3 + 2x}[/itex] = [itex]\frac{A}{x}[/itex] + [itex]\frac{Bx + C}{x2 + 2}[/itex]
1 = A(x2 + 2) + (Bx + C)(x)
1 = Ax2 + 2A + Bx2 + Cx
1 = x2( A + B) + Cx + 2A
Solving for A gives [itex]\frac{1}{2}[/itex]
Solving for B gives -[itex]\frac{1}{2}[/itex]
Solving for C gives 0
∫[itex]\frac{dx}{x(x2 + 2}[/itex] = [itex]\frac{1}{2}[/itex]∫[itex]\frac{dx}{x}[/itex] - [itex]\frac{1}{2}[/itex]∫[itex]\frac{dx}{x2 + 2}[/itex]
When we evaluate this, I get:
[itex]\frac{1}{2}[/itex]ln x - [itex]\frac{1}{2}[/itex]tan-1[itex]\frac{x}{\sqrt{2}}[/itex]
Or should it be:
[itex]\frac{1}{2}[/itex]ln x - [itex]\frac{1}{2}[/itex]ln (x2 + 2)
B was the coefficient of x in the numerator. What happened to x?
Also, don't mix tags inside of [itex] expressions. It is causing what you wrote to not render correctly.
Or should it be:
I fixed it:
And I got
Is this correct?
Why don't you check for yourself? If your answer is correct, it should be true that
d/dx[1/2 * ln(x) - (1/4) * ln(x2 + 2)] = 1/(x3 + 2x), the original integrand.
Related to Integrating Rational Functions
1. What is a rational function?
A rational function is a mathematical function that can be expressed as the ratio of two polynomial functions. It can also be written in the form of f(x) = P(x) / Q(x), where P(x) and Q(x) are polynomials and Q(x) is not equal to zero.
2. How do you integrate a rational function?
To integrate a rational function, you can use the method of partial fractions. This involves breaking down the rational function into simpler fractions that can be more easily integrated. Another method is to use the substitution method, where you substitute a variable to simplify the integral.
3. What is the purpose of integrating rational functions?
The purpose of integrating rational functions is to find the area under the curve of a given function. This can help in solving real-world problems related to rates of change, such as finding the displacement of an object or the amount of material needed for a project.
4. Are there any restrictions when integrating rational functions?
Yes, there are restrictions when integrating rational functions. The denominator of the rational function cannot be equal to zero, as this would result in an undefined value. Additionally, the degree of the numerator must be less than the degree of the denominator for the integral to converge.
5. Can rational functions be integrated using other methods?
Yes, there are other methods for integrating rational functions, such as using the power rule, trigonometric substitutions, or integration by parts. However, these methods may not be as efficient as using partial fractions or substitution, especially for more complex rational functions.
