Integrating the metric in 3-D Spherical coordinates
In summary, the conversation discusses the concept of integrating the ds in spherical coordinates to find the arc length along a curved manifold. The solution for calculating the arc length using the spherical coordinates metric is explained by using a specific example and integrating the resulting expression.
GRstudent
143
Guys,
I read that integrating the ds gives the arc length along the curved manifold. So in this case, I have a unit sphere and its metric is ds^2=dθ^2+sin(θ)^2*dψ^2. So how to integrate it? What is the solution for S?
Note, it also is known as ds^2=dΩ^2
Thanks!
Hi GRstudent! :smile:
(try using the X2 button just above the Reply box :wink:)
GRstudent said:
… integrating the ds gives the arc length along the curved manifold. So in this case, I have a unit sphere and its metric is ds^2=dθ2+sin(θ)2*dψ2. So how to integrate it? What is the solution for S?
integrate ds "dot" the expression for the curve
for example, if the curve is constant ψ, then ds = dθ ("longitude")
if the curve is constant θ, then ds = sinθdψ ("latitude")
and if the curve is neither, then you need to parametrize, for example by giving θ = θ(t), ψ=ψ(t), write ds2 = (something that depends on t) dt2 and then integrate!
I would like to get an integral solution of spherical coordinates metric.
Did you have a particular path in mind, whose arc length you want to calculate? Let's take an example: Suppose the path is defined by [itex] \phi = 2 \theta [/itex], [itex] \theta \in [0, \pi] [/itex] and the arc length is
[tex] ds^2 = d\theta^2 + \sin^2 \theta d\phi^2 [/tex]
Plugging the curve parametrization into this formula, and taking the square root, you find
[tex]ds = \sqrt{d\theta^2 + \sin^2 \theta (2 d\theta)^2} = \sqrt{1+4\sin^2\theta} d\theta [/tex]
and to find the arc length, you just integrate
[tex] s = \int_\gamma ds = \int_0^\pi \sqrt{1+4\sin^2\theta} d\theta [/tex]
Thanks!
Related to Integrating the metric in 3-D Spherical coordinates
1. What is the metric in 3-D spherical coordinates?
The metric in 3-D spherical coordinates is a mathematical tool used to measure distances and angles in a three-dimensional space. It is defined by the coefficients of the line element, which represents the infinitesimal distance between two nearby points in the space.
2. Why is it important to integrate the metric in 3-D spherical coordinates?
Integrating the metric in 3-D spherical coordinates is important because it allows us to calculate various physical quantities, such as distances, areas, and volumes, in a three-dimensional space. It also helps in solving problems in physics, engineering, and other fields that involve spherical coordinates.
3. How is the metric in 3-D spherical coordinates derived?
The metric in 3-D spherical coordinates is derived from the Pythagorean theorem and the law of cosines. By considering the infinitesimal distance between two nearby points in spherical coordinates, we can express the line element in terms of the coordinate differentials and use the Pythagorean theorem to derive the metric coefficients.
4. What are the coefficients of the metric in 3-D spherical coordinates?
The coefficients of the metric in 3-D spherical coordinates are grr, gθθ, and gφφ, which represent the squares of the scale factors in the radial, polar, and azimuthal directions, respectively. These coefficients depend on the coordinate values and determine the properties of the space in spherical coordinates.
5. How is the metric in 3-D spherical coordinates integrated?
The metric in 3-D spherical coordinates is integrated by using the appropriate integration techniques for each coefficient. For example, to integrate grr, we use the substitution method, while for gθθ and gφφ, we use trigonometric identities. The resulting integrals can then be simplified and evaluated to obtain the desired physical quantity.
