wrldt
- 13
A particle of mass m is confined to move in a one-dimensional and Diract delta-function attractive potential [itex]V(x)=-\frac{\hbar^2}{m}\alpha\delta(x)[/itex] where [itex]\alpha[/itex] is positive.
Integrate eh time-independent Schrodinger equation between [itex]-\epsilon[/itex] and [itex]\epsilon[/itex]. Let [itex]\epsilon\to 0[/itex], show that the derivative of the eigenfunction [itex]\phi(x)[/itex] is discontinuous at x=0, and determine its jump at the point.
[itex]\frac{\hbar^2}{2m}\frac{\partial^2 \psi}{\partial x^2}-V(x)\psi=E\psi[/itex]
First I want to determine if I am approaching the problem correctly.
First we have:
[itex]\int\limits_{-\epsilon}^{\epsilon}-\frac{\hbar^2}{2m}\frac{\partial^2 \psi}{\partial x^2}+\int\limits_{-\epsilon}^{\epsilon}\frac{\hbar^2}{m}\alpha\delta(x)\psi=\int\limits_{-\epsilon}^{\epsilon}E\psi[/itex].
Then this simplifies to
[itex]\int\limits_{-\epsilon}^{\epsilon}\frac{\hbar^2}{m}\alpha\delta\psi=\int\limits_{-\epsilon}^{\epsilon}\frac{\hbar^2}{2m}\frac{\partial^2 \psi}{\partial x^2}[/itex]
Further simplifying
[itex]2\alpha\int\limits_{-\epsilon}^{\epsilon}\delta(x)\psi(x)=\frac{\partial \psi}{\partial x}\bigg|_{-\epsilon}^{\epsilon}[/itex]
The last equation shows that as $\epsilon \to 0$, the right hand side will tend to zero but the left hand side will explode. I'm wondering if my work sufficiently shows this.
The part I am stuck on is showing what its jump is at x=0.
