Integration bounds in a continuous charge distribution of a semicircle
In summary, the integration bounds in a continuous charge distribution of a semicircle are determined by the radius and angle of the semicircle, and they help to define the area being considered for integration. They cannot be negative and directly impact the total charge within the semicircle, as well as the shape of the semicircle itself.
vantz
Why are the integration bounds from -pi/2 to pi/2 and not 0 to pi?
Because the angle is with respect to the positive y-axis.
what's the proof? I can't understand why this is the case
Thank you
Thank you
Look at the diagram. Note where the angle θ is. If θ was 2π, where would that put the radius vector?
The reason for choosing integration bounds from -pi/2 to pi/2 for a continuous charge distribution of a semicircle is due to the symmetry of the problem. A semicircle has a symmetrical shape, with its center at the origin and its endpoints at (-1,0) and (1,0). This symmetry allows us to divide the semicircle into two equal halves, each with a width of pi/2. By choosing integration bounds from -pi/2 to pi/2, we are essentially integrating over one half of the semicircle and then multiplying the result by 2 to get the total charge.
On the other hand, choosing integration bounds from 0 to pi would result in integrating over the entire semicircle, which would lead to double counting of the charge. This is because the area under the curve from 0 to pi is equal to the area from pi to 2pi, which is essentially the same area as the first half of the semicircle. Therefore, by choosing integration bounds from -pi/2 to pi/2, we are able to avoid this double counting and obtain an accurate result for the total charge in the semicircle.
In summary, the choice of integration bounds from -pi/2 to pi/2 for a continuous charge distribution of a semicircle is based on the symmetry of the problem, which allows us to accurately calculate the total charge without double counting.
Related to Integration bounds in a continuous charge distribution of a semicircle
1. How do you determine the integration bounds in a continuous charge distribution of a semicircle?
The integration bounds in a continuous charge distribution of a semicircle are determined by the limits of the semicircle's radius and angle. The radius determines the distance from the center of the semicircle to the outer edge, while the angle determines the portion of the semicircle that is being considered for the integration.
2. What is the significance of integration bounds in a continuous charge distribution of a semicircle?
The integration bounds in a continuous charge distribution of a semicircle help to define the area of the semicircle that is being considered for the integration. This is important in accurately calculating the total charge within the semicircle and understanding the distribution of the charge.
3. Can the integration bounds in a continuous charge distribution of a semicircle be negative?
No, the integration bounds in a continuous charge distribution of a semicircle cannot be negative. This is because the radius and angle of a semicircle cannot be negative values. If the integration bounds appear to be negative, it is likely due to a mistake in calculation or interpretation.
4. How does the integration bounds in a continuous charge distribution of a semicircle affect the total charge within the semicircle?
The integration bounds in a continuous charge distribution of a semicircle determine the region over which the charge is being integrated. This means that the integration bounds directly impact the total charge within the semicircle. Different integration bounds will result in different values for the total charge.
5. What is the relationship between the integration bounds and the shape of a continuous charge distribution of a semicircle?
The integration bounds in a continuous charge distribution of a semicircle are closely tied to the shape of the semicircle. The integration bounds determine the area over which the charge is being integrated, and the shape of the semicircle helps to define the limits of the integration bounds. A change in the integration bounds will result in a change in the shape of the semicircle and vice versa.
