MHB Integration by Partial Fraction Decomposition - Yahoo Answers
The discussion focuses on solving the integral ∫ (x^5 + 2x^3 - 3x)dx / (x^2 + 1)^3 using partial fraction decomposition. The numerator is factored to x(x + 1)(x - 1)(x^2 + 3), and the integrand is expressed in terms of partial fractions with repeated quadratic factors. By equating coefficients after expanding the right side, the constants A, B, C, D, E, and F are determined, leading to the decomposition of the integrand. The integral is then solved using substitution, resulting in the final expression involving the natural logarithm and a polynomial term. This method illustrates the process of integrating rational functions through partial fraction decomposition.
MarkFL
MHB
Here is the question:
I have problems solving this(integration by partial fractions)?
I really don't know. Partial fractions. I know that you're supposed to do something like Ax+B when it comes to quadratic eqn's and you're supposed to give another arbitrary constant when it's raised to a power. but I don't think I can do it unless there's something else with it and I have no idea how to factor it. I really should've listened to our earlier algebra classes. :(
I have posted a link there so the OP can view my work.
Mathematics news on Phys.org
Hello Vi3nc6en0t,
We are given to evaluate:
$$\int\frac{x^5+2x^3-3x}{\left(x^2+1 \right)^3}\,dx$$
First, we observe that the numerator of the integrand can be factored:
$$x^5+2x^3-3x=x\left(x^4+2x^2-3 \right)=x\left(x^2+3 \right)\left(x^2-1 \right)=x(x+1)(x-1)\left(x^2+3 \right)$$
Thus, there are no common factors to divide out. To complete the partial fraction decomposition, we observe that an integrand with a repeated quadratic factor will decompose as follows:
$$\frac{P(x)}{\left(ax^2+bx+c \right)^n}=\sum_{k=1}^n\left(\frac{A_kx+B_k}{\left(ax^2+bx+c \right)^k} \right)$$
Thus, for the given integrand, we may write:
$$\frac{x^5+2x^3-3x}{\left(x^2+1 \right)^3}=\frac{Ax+B}{x^2+1}+\frac{Cx+D}{\left(x^2+1 \right)^2}+\frac{Ex+F}{\left(x^2+1 \right)^3}$$
Multiplying through by $$\left(x^2+1 \right)^3$$, we obtain:
$$x^5+2x^3-3x=(Ax+B)\left(x^2+1 \right)^2+(Cx+D)\left(x^2+1 \right)+(Ex+F)$$
Expanding the right side and arranging on like powers of $x$, we obtain:
$$x^5+2x^3-3x=Ax^5+Bx^4+(2A+C)x^3+(2B+D)x^2+(A+C+E)x+(B+D+F)$$
Equating corresponding coefficients, we obtain the system:
$$A=1$$
$$B=0$$
$$2A+C=2\implies C=0$$
$$2B+D=0\implies D=0$$
$$A+C+E=-3\implies E=-4$$
$$B+D+F=0\implies F=0$$
Thus, we may state:
$$\frac{x^5+2x^3-3x}{\left(x^2+1 \right)^3}=\frac{x}{x^2+1}-\frac{4x}{\left(x^2+1 \right)^3}$$
Now, in order to integrate, let's write:
$$\int\frac{x^5+2x^3-3x}{\left(x^2+1 \right)^3}\,dx=\frac{1}{2}\int\frac{2x}{x^2+1}\,dx-2\int\frac{2x}{\left(x^2+1 \right)^3}\,dx$$
For both integrals, consider the substitution:
$$u=x^2+1\,\therefore\,du=2x\,dx$$
And we may now write:
$$\int\frac{x^5+2x^3-3x}{\left(x^2+1 \right)^3}\,dx=\frac{1}{2}\int\frac{1}{u}\,du-2\int u^{-3}\,du$$
Applying the rules of integration, we obtain:
$$\int\frac{x^5+2x^3-3x}{\left(x^2+1 \right)^3}\,dx=\frac{1}{2}\ln|u|-2\frac{u^{-2}}{-2}+C$$
Back substituting for $u$, and applying the property of logs that a coefficient may be taken inside as an exponent we have:
$$\int\frac{x^5+2x^3-3x}{\left(x^2+1 \right)^3}\,dx=\ln\left(\sqrt{x^2+1} \right)+\frac{1}{\left(x^2+1 \right)^2}+C$$
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
