Integration by parts involving partial derivatives
In summary: That's correct. Thanks.If the integral was a definite integral, then the constant of integration would be a definite function of t. However, for the purpose of this problem, the constants will still be arbitrary functions of t since the integral is still just f.
tjkubo
42
[tex]
\int x \frac {\partial f} {\partial x} dx
[/tex]
where
[tex]f=f(x,t)[/tex]
[tex]
\int u \, dv = uv - \int v \, du
[/tex]
[tex]
u = x [/tex] so [tex]du = dx [/tex]
and
[tex]
dv = \frac {\partial f} {\partial x} dx[/tex] so [tex]v = \int \frac {\partial f} {\partial x} dx = f?
[/tex]
Are these the correct substitutions? I am especially hesitant about the last term, so can anyone explain why it's right/wrong?
you'd get v=f(x,t) + h(t)
EDIT: Sorry, there'd be no h(t)...
tjkubo said:
[tex]
and
[tex]
[/tex]
The term you are hesitant about is correct. You are integrating, with respect to x, the derivative of f with respect to x, so by the fundamental theorem of calculus that integral is just f.
So, you're right. Just finish the integration by parts and you're done!
Just be sure to remember that the "constant" of integration in this case isn't constant--it's an arbitrary function of t.
What if the integral was a definite integral? Would the final result be some function of t only? And would you disregard the arbitrary function of t?
You wouldn't disregard it nor do you just disregard it for a normal integral. What happens when you evaluate a definite integral is that the constants get subtracted from each other.
[tex]
f(x,t)+h(t)]_{x_1}^{x_2}=f(x_1,t)+h(t)-(f(x_2,t)+h(t))=f(x_1,t)-f(x_2,t)
[/tex]
FAQ: Integration by parts involving partial derivatives
1. What is integration by parts involving partial derivatives?
Integration by parts involving partial derivatives is a method used in calculus to solve integrals that involve both partial derivatives and functions. It is an extension of the integration by parts rule, which is used to solve integrals of products of functions.
2. When is integration by parts involving partial derivatives used?
This method is used when the integrand contains a product of functions that cannot be easily integrated, but can be differentiated. It is especially useful when the integrand contains a function that is difficult to integrate, such as trigonometric or logarithmic functions.
3. How does integration by parts involving partial derivatives work?
The formula for integration by parts involving partial derivatives is ∫f(x)g'(x)dx = f(x)g(x) - ∫g(x)f'(x)dx. This means that the integral of the product of two functions is equal to the product of the first function and the antiderivative of the second function, minus the integral of the antiderivative of the first function and the second function.
4. What are the steps for solving an integral using integration by parts involving partial derivatives?
The steps for solving an integral using this method are: 1) Identify the parts of the integrand that can be differentiated and integrated, 2) Choose u and dv for integration by parts, 3) Calculate du and v, 4) Substitute the values for du and v into the integration by parts formula, and 5) Simplify and solve for the integral.
5. Are there any tips for using integration by parts involving partial derivatives?
One tip for using this method is to choose u and dv in a way that will simplify the integral as much as possible. Another tip is to make sure to keep track of the signs and constants when substituting values into the integration by parts formula. Practice and familiarity with different types of integrals will also help in using this method effectively.
