MHB Integration by Parts: Showing $\ln^n(1-x)$
The discussion focuses on deriving the integral of $\frac{\ln^{n}(1-x)}{x}$ using integration by parts, leading to a formula involving the polylogarithm function $\text{Li}_{n}(x)$. The result shows that for $n > 1$, the integral can be expressed as a sum of terms involving $\ln x$ and polylogarithms, with a constant of integration. Participants also explored alternative methods, including substitutions and series expansions, to approach the integral. The conversation reflects a lack of engagement, possibly due to the perceived complexity or monotony of the topic. Ultimately, the integration by parts technique effectively reveals the relationship between logarithmic functions and polylogarithms in this context.
polygamma
Integration by parts
By repeatedly integrating by parts show that for $ n >1 $,
$$ \int \frac{\ln^{n}(1-x)}{x} \ dx = \ln x \ln^{n}(1-x) + \sum_{k=1}^{n} (-1)^{k-1} \frac{n!}{(n-k)!} \text{Li}_{k+1}(1-x) \ln^{n-k} (1-x) + C$$
where $\text{Li}_{n}(x)$ is the polylogarithm function of order $n$.
Mathematics news on Phys.org
This problem didn't' generate much interest. Perhaps it was too boring.$ \displaystyle \int \frac{\ln^{n}(1-x)}{x} \ dx $Let $ \displaystyle u = \ln^{n}(1-x)$ and $ \displaystyle dv = \frac{dx}{x}$.$ = \displaystyle - \ln x \ln^{n}(1-x) + n \int \frac{\ln x \ln^{n-1} (1-x)}{1-x} \ dx $Let $\displaystyle u = \ln^{n-1}(1-x)$ and $\displaystyle dv = \frac{\ln x}{1-x} \ dx$.$ \displaystyle = \ln x \ln^{n}(1-x) + \text{Li}_{2}(1-x) \ln^{n-1}(1-x) + n (n-1) \int \frac{\text{Li}_{2}(1-x) \ln^{n-2}(1-x)}{1-x} \ dx $Let $\displaystyle u = \ln^{n-2}(1-x)$ and $\displaystyle dv = \frac{\text{Li}_{2}(1-x)}{1-x} \ dx $.$ = \displaystyle \ln x \ln^{n}(1-x) + n \text{Li}_{2}(1-x) \ln^{n-1}(1-x) - n(n-1)\text{Li}_{3}(1-x) \ln^{n-2}(1-x)$
$ \displaystyle - n(n-1)(n-2) \int \frac{\text{Li}_{3} \ln^{n-3} (1-x)}{1-x} \ dx $$ = \displaystyle \ln x \ln^{n}(1-x) + n \text{Li}_{2}(1-x) \ln^{n-1}(1-x) - n(n-1)\text{Li}_{3}(1-x) \ln^{n-2}(1-x) $
$ \displaystyle + n(n-1)(n-2) \text{Li}_{4}(1-x) \ln^{n-3}(1-x) + n(n-1)(n-2)(n-3) \int \frac{\text{Li}_{4}(1-x)\ln^{n-4}(1-x)}{1-x} \ dx $$ \displaystyle = \ldots = \ln x \ln^{n}(1-x) + n \text{Li}_{2}(1-x) \ln^{n-1}(1-x) - n(n-1)\text{Li}_{3}(1-x) \ln^{n-2}(1-x)$
$\displaystyle + \ldots + (-1)^{n} (n-1)! \text{Li}_{n} \ln (1-x) \ dx + (-1)^{n} n! \int \frac{\text{Li}_{n}(1-x)}{1-x} \ dx $$ \displaystyle = \ln x \ln^{n}(1-x) + n \text{Li}_{2}(1-x) \ln^{n-1}(1-x) - n(n-1)\text{Li}_{3}(1-x) \ln^{n-2}(1-x)$
$ \displaystyle + \ldots + (-1)^{n} (n-1)! \text{Li}_{n} \ln (1-x) \ dx + (-1)^{n-1} n! \text{Li}_{n+1}(1-x) + C $$\displaystyle = \ln x \ln^{n}(1-x) + \sum_{k=1}^{n} (-1)^{k-1} \frac{n!}{(n-k)!} \text{Li}_{k+1}(1-x) \ln^{n-k} (1-x) + C $But actually you can express it more succinctly since $ \displaystyle \ln x = - \text{Li}_{1}(1-x)$.So $ \displaystyle \int \frac{\ln^{n}(1-x)}{x} \ dx = \sum_{k=0}^{n} (-1)^{k-1} \frac{n!}{(n-k)!} \text{Li}_{k+1}(1-x) \ln^{n-k} (1-x) + C $And it's valid for $n=1$ as well.
I proved a similar forumla a while back
$$\int^a_0 \frac{\log^n(x)}{1-x}\, dx = \log^n(a) \sum_{k=0}^{n}(-1)^k\frac{ n!}{(n-k)!}\,\frac{\text{Li}_{k+1}(a)}{\log^k(a)} $$
I used the binomial expansion .
I'd be inclined to skin this particular transcendental cat slightly differently... Firstly, apply the reflection substitution $$x \to 1-x$$, to obtain
$$\int \frac{\log^n(1-x)}{x}\,dx=\int \frac{(\log x)^n}{(1-x)}\, dx$$Then expand the denominator as an infinite series$$\frac{1}{1-x}=\sum_{k=0}^{\infty}x^k$$
Insert this into the indefinite integral, and then integrate term-by-term...$$\int \frac{\log^n(1-x)}{x}\,dx=\sum_{k=0}^{\infty} \int x^k(\log x)^n\, dx$$
EDIT: You beat me to it, Zaid... I must confess, I never bother with integrals like these in indefinite form, so like you, I did the parametric case... (Cool)
Here is how I did it Using a substitution we obtain
$$a\int^{1}_0 \frac{\log^n(ax)}{1-ax}\, dx $$
which can be written as
$$a\int^{1}_0 \frac{\left(\log(a)+\log(x) \right)^n}{1-ax}\, dx $$
Now using that binomial expansion we have
$$a\int^{1}_0 \sum_{k=0}^{n} {n \choose k} \log^{n-k}(a) \log^k(x) \frac{ dx}{1-ax}\, $$
arranging to obtain
$$a \sum_{k=0}^{n}{n \choose k}\log^{n-k}(a)\int^{1}_0 \frac{\log^k(x) }{1-ax}\,dx $$
$$\sum_{k=0}^{n}(-1)^ k {n \choose k}\log^{n-k}(a) \Gamma(k+1) \text{Li}_{k+1}(a) $$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
