Integration (Enclosed Area & Rotation Volume)
In summary: The problem is trying to find the area of a region that is generated by rotating about an axis. In summary, the area enclosed by the curve x=3+cos(t) and y=4sin(t) is A=-4. The volume of the solid generated by revolving about the y-axis the area between the first arc of the cycloid x=t-sin(t), y=1-cos(t) and the x-axis is v=2pi integral (t-sin(t)) (1-cos(t))^2 dt.
Latios1314
45
1) Find the area enclosed by the curve x=3+cos(t) and y=4sin(t).
My tutor gave me a hint which confuses me.
A=-4 integral y dx where the upper limit is pi/2 and the lower limit is 0.
I do not understand the -4 part. why must we multiply the integral by -4?
2) Find the volume of the solid generated by revolving about the y-axis the area between the first arc of the cycloid x=t-sin(t), y=1-cos(t) and the x-axis. Use the shell method.
v=2pi integral xy dx
I'm stuck at this point.
could anyone help me with these two questions?
anyone?=/
If x= 3+cos(t) and y= 4 sin(t), then cos(t)= x- 3 and sin(t)= y/4 so that [itex](x- 3)^2+ y^2/16= sin^2(t)+ cos^2(t)= 1[/itex]. The figure is an ellipse with center at (3, 0), minor semi-axis on the x-axis, of length 1, and major semi-axis parallel to the y-axis, of length 4. The area of such an ellipse is [itex]\pi[/itex] times the product of the two semi-axes, here, [itex]4\pi[/itex].
A "standard" parameterization for a circle would be "x= R cos(t), y= R sin(t)" where R is the radius and t goes around the full circle, from 0 to [itex]2\pi[/itex]. Using different "R" for x and y (1 and 4) gives an ellipse rather than a circle. Going from 0 to [itex]\pi/2[/itex] gives you 1/4 of the ellipse. Because of the symmetry, multiplying that by 4 will give the area of the entire ellipse. The negative is because with x= R cos(t) (or x= cos(t)+ 3), [itex]dx= -R sin(t)dt[/itex].
You can also see this as a special case of Greens Theorem:
[tex]\int\int_D \left(\frac{\partial M}{\partial x}- \frac{\partial N}{\partial y}\right) dxdy= \oint Ndx+ Mdy[/tex]
In particular, if we take M= 0 N= y the left side becomes [itex]\int\int_D -1 dxdy[/itex] which is just the negative of the area of region D. The right side becomes [itex]\oint y dx[/itex] where the integral is around the circumference of the region.
However, this problem has nothing to do with "volume of rotation" or even "volume".
FAQ: Integration (Enclosed Area & Rotation Volume)
What is meant by "integration" in the context of enclosed area and rotation volume?
Integration is a mathematical process used to find the total sum of a function's values by dividing it into infinitely small intervals and adding them together. In the context of enclosed area and rotation volume, integration is used to calculate the total area or volume enclosed by a curve or surface.
How is integration used to find the enclosed area under a curve?
To find the enclosed area under a curve, integration is used to calculate the definite integral of the function representing the curve. This involves dividing the curve into smaller intervals, finding the area of each interval, and adding them together to get the total enclosed area.
Can integration be used to find the volume of a solid formed by rotating a curve around an axis?
Yes, integration can be used to find the volume of a solid formed by rotating a curve around an axis. This is known as the method of cylindrical shells, where the volume is calculated by integrating the product of the circumference of the shell and its height.
What is the difference between using integration to find the area and volume of a 2D shape versus a 3D shape?
The main difference is the number of dimensions involved. Integration is used to find the area of a 2D shape by integrating a function representing the curve. On the other hand, integration is used to find the volume of a 3D shape by integrating a function representing the cross-sectional area of the shape.
Are there any practical applications of integration in real-world scenarios?
Yes, integration has many practical applications in fields such as physics, engineering, and economics. For example, it can be used to calculate the work done by a force, the center of mass of an object, or the total revenue of a business. It is also essential in optimization problems, where it is used to find the maximum or minimum value of a function.
