MHB Integration in Polar Coordinates (Fubini/Tonelli)
joypav
Let $S^{n-1} = \left\{ x \in R^2 : \left| x \right| = 1 \right\}$ and for any Borel set $E \in S^{n-1}$ set $E* = \left\{ r \theta : 0 < r < 1, \theta \in E \right\}$. Define the measure $\sigma$ on $S^{n-1}$ by $\sigma(E) = n \left| E* \right|$.
With this definition the surface area $\omega_{n-1}$ of the sphere in $R^n$ satisfies $\omega_{n-1} = n \gamma_n = \frac{2 \pi^{n/2}}{\Gamma (n/2)}$, where $\gamma_n$ is the volume of the unit ball in $R^n$. Prove that for all non-negative Borel functions $f$ on $R^n$,
$\int_{R^n} f(x) dx = \int_0^{\infty} r^{n-1} (\int_{S^{n-1}} f(r \theta ) d \sigma (\theta) ) dr $.
In particular, if $f$ is a radial function, then ($f$ radial $\implies f(x) = f(\left| x \right|)$)
$\int_{R^n} f(x) dx = \frac{2 \pi^{n/2}}{\Gamma (n/2)} \int_0^{\infty} r^{n-1} f(r) dr = n \gamma_n \int_0^{\infty} r^{n-1} f(r) dr$.
I admit my head is spinning over this problem. Can someone give me an idea of the proof or explain the idea of it more clearly...
Also, this problem is in the section for Fubini/Tonelli Theorems.
$\newcommand{\set}[1]{\{#1\}}$
$\newcommand{\vp}{\varphi}$
$\newcommand{\mc}{\mathcal}$
$\newcommand{\R}{\mathbf R}$Let $(X, \mc X, \mu)$ be a measure space and $(Y, \mc Y)$ be a measurable space and let $\vp:X\to Y$ be a measurable function.
We define the push-forward of $\mu$ via $\vp$ as a measure on $(Y, \mc Y)$, which we denote by $\vp_*\mu$, by declaring $(\vp_*\mu)(E)=\mu(\vp^{-1}(E))$ for all $E\in \mc Y$.
A key theorem, which is easy to prove, is that if $g:Y\to \R$ is a measurable function such that $g\circ f$ is an integrable function on $X$, the we have
\begin{equation}
\int_X g\circ \vp\ d\mu = \int_Y g\ d(\vp_*\mu)
\end{equation}
We will use this theorem to solve the problem at hand.
We have a natural map $\vp: (0, \infty)\times S^{n-1}\to \R^n\setminus\set{0}$ which sends $(r, \theta)$ to $r\theta$.
Write $\nu$ to denote the Lebesgue measure on $\R^n\setminus \set{0}$.
Define a measure $\mu$ on $(0, \infty)\times S^{n-1}$ as $\mu=\vp^{-1}_*\nu$.
The main observation is that if $\lambda$ is the Lebesgue measure on $\R$, then the measure $\mu$ is the product $\alpha\times \sigma$, where $\alpha$ is given by $d\alpha= x^{n-1} d\lambda$.
So we have
\begin{equation}
\int_{\R^n}f\ d\nu =\int_{\R^n\setminus \set{0}} f\ d\nu = \int_{(0, \infty)\times S^{n-1}} f\circ \vp\ d(\alpha\times \sigma)
\end{equation}
Now by Fubini
\begin{equation}
\int_{(0, \infty)\times S^{n-1}} f\circ \vp\ d(\alpha\times \sigma) = \int_0^\infty \left(\int_{S^{n-1}} f\circ \vp(r, \theta) \ d\sigma(\theta)\right) d\alpha(r)
\end{equation}
which is, by the fact that $d\alpha=x^{n-1} \ d\lambda$, is
\begin{equation}
\int_0^\infty \left(\int_{S^{n-1}} f\circ \vp(r, \theta) \ d\sigma(\theta)\right) d\alpha(r)=\int_0^\infty r^{n-1} \left(\int_{S^{n-1}} f(r\theta) \ d\sigma(\theta)\right) d\lambda(r)
\end{equation}
Thank you!
Makes sense. I wonder why we haven't seen the "push forward"? (Wondering)
In the very first integral, is that meant to be $d\lambda$?
joypav said:
Thank you!
I am using $\nu$ to denote the Lebesgue measure on $\mathbb R^n$ and $\lambda$ to denote the Lebesgue measure on $\mathbb R$.
\begin{equation}
\end{equation}
So we have
\begin{equation}
\end{equation}
Now by Fubini
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
sorry if I am re opening this , I have the same problem , can you explain why $\mu$ is the product $\alpha\times \sigma$, where $\alpha$ is given by $d\alpha= x^{n-1} d\lambda$.? Really thanks
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
