Integration in polar coordinates
In summary, the conversation discusses the volume integral over a sphere of radius R in spherical polar coordinates and its relation to the surface integral. It is also mentioned that the divergence of a vector in this scenario is equal to 4π times the delta function in three dimensions. The divergence is only non-zero at r=0, and in order to integrate to 4π, it must be 4π times the delta function.
Apashanka
429
In spherical poler coordinates the volume integral over a sphere of radius R of $$\int^R_0\frac{\hat r}{r^2}dv=\int_{surface}\frac{\hat r}{r^2}•\vec ds$$
$$=4\pi$$
$$=4\pi$$
In spherical poler coordinates the volume integral over a sphere of radius R of $$\int^R_0\vec \nabla•\frac{\hat r}{r^2}dv=\int_{surface}\frac{\hat r}{r^2}•\vec ds$$
$$=4\pi=4\pi\int_{-\inf}^{inf}\delta(r)dr$$
How can it be extended to get $$\vec \nabla•\frac{\hat r}{r^2}=4\pi\delta^3(r)??$$
I am unclear on what you are given and what you are trying to show.
Apashanka said:
$$\int^R_0\frac{\hat r}{r^2}dv$$
The bounds don't match the integration variable (dv). You mean
$$\int_V\frac{\hat r}{r^2}dv$$
This seems to be identical to your earlier equation except for the Del on the left. They can't both be true.
The only possibly relevant interpretation is
\int_{r < R} \nabla \cdot \frac{\hat r}{r^2} dV
Without the divergence operator, the expression is a vector that obviously cannot equal a scalar.
Of course, OP should be careful in formulating the original post such that this ambiguity does not arise.
Ya in this case the Rhs equals $$4\pi$$.
What I want to clarify is $$\vec \nabla•\frac{\hat r}{r^2}=4\pi\delta^3(r)$$
The divergence is zero everywhere except in r=0, as can be easily verified by using the expression for divergence in spherical coordinates. In order to integrate to ##4\pi##, the divergence therefore must be ##4\pi\delta^{(3)}(\vec r)##.
FAQ: Integration in polar coordinates
What is integration in polar coordinates?
Integration in polar coordinates is a mathematical technique used to find the area under a curve in polar coordinates. It involves converting the polar equation into an equivalent Cartesian equation and then using standard integration techniques to find the area.
Why is integration in polar coordinates useful?
Integration in polar coordinates allows us to find the area of complex shapes that cannot be easily expressed in Cartesian coordinates. It is especially useful in fields such as physics and engineering, where many problems involve circular or rotational symmetry.
What are the steps involved in integrating in polar coordinates?
The steps involved in integrating in polar coordinates include converting the polar equation into an equivalent Cartesian equation, determining the limits of integration, and then using standard integration techniques to find the area. These techniques may include substitution, integration by parts, or partial fractions.
What are the limitations of integration in polar coordinates?
Integration in polar coordinates is limited to finding the area of shapes with circular or rotational symmetry. It cannot be used to find the volume of three-dimensional shapes or the area of shapes with irregular boundaries.
How can I practice and improve my skills in integrating in polar coordinates?
You can practice by solving a variety of problems involving integration in polar coordinates. You can also use online resources and textbooks to learn more about the technique and its applications. Additionally, seeking help from a tutor or attending a workshop can also help improve your skills in integrating in polar coordinates.
