Integration involving substitutions II
  • MHB
  • Thread starter paulmdrdo1
  • Tags
    Integration
In summary: Let me try to explain it another way. In order to use trigonometric substitution, we need to be able to rewrite the integrand in terms of a trigonometric function. In this case, we are able to do that because of the Pythagorean identity:\tan^2(\theta)=\sec^2(\theta)-1Now, let's look at the integral again:\int\frac{1}{u\sqrt{16u^2-9}}\,duThe first thing I notice is that the denominator contains a square root, which usually means it is a good idea to try and use a trigonometric substitution. So, I think to myself, "is there a trig
paulmdrdo1
385
\begin{align*}\displaystyle \int\frac{du}{u\sqrt{16u^2-9}}\\& let\,\acute{u} =\,4u\\&d\acute{u}=4du\\&du=\frac{1}{4}(d\acute{u})\\ &\frac{1}{4}\int\frac{d\acute{u}}{\acute{u}\sqrt{(\acute{u})^2-a^2}}\\ & =\frac{1}{12}sec^{-1}\frac{4}{3}u+c -->> is\, this\, correct?\end{align*}
Re: Integration Inverse trig II
It's better to use a different letter for a new variable, I know you've changed the symbol slightly but it's difficult to read.
Anyway, it's not correct, as the u outside the square root should become \(\displaystyle \displaystyle \begin{align*} \frac{u'}{4} \end{align*}\).
My approach for this question would be to use hyperbolic and trigonometric substitution. Let \(\displaystyle \displaystyle \begin{align*} 4u = 3\cosh{(t)} \implies du = \frac{3}{4}\sinh{(t)}\,dt \end{align*}\) and the integral becomes
\(\displaystyle \displaystyle \begin{align*} \int{\frac{du}{u \,\sqrt{ \left( 4u \right) ^2 - 9 } } } &= \int{\frac{\frac{3}{4}\sinh{(t)}\,dt}{\frac{3}{4} \cosh{(t)}\sqrt{ \left[ 3\cosh{(t)} \right] ^2 - 9 }}} \\ &= \int{ \frac{\sinh{(t)}\,dt}{\cosh{(t)}\sqrt{9\cosh^2{(t)} - 9}} } \\ &= \int{ \frac{\sinh{(t)}\,dt}{\cosh{(t)}\sqrt{9 \left[ \cosh^2{(t)} - 1 \right] }} } \\ &= \int{\frac{\sinh{(t)}\,dt}{\cosh{(t)}\sqrt{9\sinh^2{(t)}}}} \\ &= \int{\frac{\sinh{(t)}\,dt}{3\cosh{(t)}\sinh{(t)}}} \\ &= \frac{1}{3} \int{ \frac{dt}{\cosh{(t)}} } \\ &= \frac{1}{3} \int{ \frac{\cosh{(t)}\,dt}{\cosh^2{(t)}} } \\ &= \frac{1}{3} \int{ \frac{\cosh{(t)}\,dt}{1 + \sinh^2{(t)}} } \end{align*}\)
Now let \(\displaystyle \displaystyle \begin{align*} \sinh{(t)} = \tan{(\theta)} \implies \cosh{(t)}\,dt = \sec^2{(\theta)} \,d\theta \end{align*}\) and the integral becomes
\(\displaystyle \displaystyle \begin{align*} \frac{1}{3} \int{ \frac{\cosh{(t)}\,dt}{1 + \sinh^2{(t)}} } &= \frac{1}{3} \int{ \frac{\sec^2{(\theta)} \,d\theta}{1 + \tan^2{(\theta)}} } \\ &= \frac{1}{3} \int{ \frac{\sec^2{(\theta)}\,d\theta}{\sec^2{(\theta)}} } \\ &= \frac{1}{3} \int{ 1\,d\theta} \\ &= \frac{1}{3} \theta + C \\ &= \frac{1}{3}\arctan{ \left[ \sinh{(t)} \right] } + C \\ &= \frac{1}{3} \arctan{ \left[ \sqrt{ \cosh^2{(t)} - 1 } \right] } + C \\ &= \frac{1}{3} \arctan{ \left[ \sqrt{ \left( \frac{4u}{3} \right) ^2 - 1 } \right] } + C \\ &= \frac{1}{3} \arctan{ \left[ \frac{\sqrt{16u^2 - 9}}{3} \right] } + C \end{align*}\)
\begin{align*}\displaystyle \int\frac{du}{u\sqrt{16u^2-9}}\\& let\,\acute{u} =\,4u\\&d\acute{u}=4du\\& a = 3 \\& du=\frac{1}{4}(d\acute{u} )\\ &\frac{1}{4}\int\frac{d\acute{u}}{\acute{u}\sqrt{({u'})^2-a^2}}\\ & =\frac{1}{12}sec^{-1}\frac{4}{3}u+c\end{align*}
this is the other part of my solution
\begin{align*}\displaystyle\frac{1}{4}(\frac{1}{a}sec^{-1}\frac{u'}{a}) + c\end{align*}
since a = 3 and u' = 4u i substituted it to have
\begin{align*}\displaystyle\frac{1}{4}(\frac{1}{3}sec^{-1}\frac{4u}{3}) + c\\ \frac{1}{12}sec^{-1}\frac{4}{3}u+c\end{align*}
can you tell me what did i do wrong. please.
It appears to me that you are using a table of integrals, such as:
\(\displaystyle \int\frac{dx}{x\sqrt{x^2-a^2}}=\frac{1}{a}\sec^{-1}\left(\frac{x}{a} \right)+C\)
Applying this to your problem, you should write:
\(\displaystyle \int\frac{du}{u\sqrt{16u^2-9}}=\int\frac{4\,du}{4u\sqrt{(4u)^2-3^2}}=\frac{1}{3}\sec^{-1}\left(\frac{4u}{3} \right)+C\)
You should be able to demonstrate that this is equivalent to the result posted by Prove It.
I will try to walk you through how I would approach this problem using a trigonometric substitution. We are given to evaluate:
\(\displaystyle \int\frac{1}{u\sqrt{16u^2-9}}\,du=\int\frac{1}{u\sqrt{(4u)^2-3^2}}\,du\)
Now, when I look at the radicand in the denominator, I think of the Pythagorean identity:
\(\displaystyle \tan^2(\theta)=\sec^2(\theta)-1\)
So, this leads me to make the substitution:
\(\displaystyle 4u=3\sec(\theta)\,\therefore\,4\,du=3\sec(\theta) \tan(\theta)\,d\theta\)
and this transforms the indefinite integral to:
\(\displaystyle \int\frac{\frac{3}{4}\sec(\theta)\tan(\theta)}{ \frac{3}{4}\sec(\theta)\sqrt{3^2\sec^2(\theta)-3^2}}\,d\theta=\int\frac{\sec(\theta)\tan(\theta)}{3\sec(\theta)\tan(\theta)}\,d\theta= \frac{1}{3}\int\,d\theta=\frac{1}{3}\theta+C\)
Now, using our substitution, we may solve for $\theta$:
\(\displaystyle 4u=3\sec(\theta)\)
\(\displaystyle \theta=\sec^{-1}\left(\frac{4u}{3} \right)\)
and so we may conclude:
\(\displaystyle \int\frac{1}{u\sqrt{16u^2-9}}\,du=\frac{1}{3}\sec^{-1}\left(\frac{4u}{3} \right)+C\)
i'm still confused about trigonometric substitution. i only use table of integrals leading to inverse trig functions. please enlighten me with trig substitution. what are the rules for that?
I am trying my best to do just that...at what point in my post do I lose you?
\begin{align*}\displaystyle tan^2(\theta)=\sec^2(\theta)-1\end{align*} you used this identities.
and you \begin{align*}\displaystyle let\, 4u=3sec(\theta)\, where\, did\, tan^2(\theta)+1\, go? why\, only\, use\, sec(\theta)\end{align*}
paulmdrdo said:
\begin{align*}\displaystyle \tan^2(\theta)=\sec^2(\theta)-1\end{align*} you used this identities.
and you let 4u=3sec where did tan2-1 go? why only use sec?
We see that we want to transform:
\(\displaystyle (4u)^2-3^2\)
and given that:
\(\displaystyle 3^2\tan^2(\theta)=3^2\sec^2(\theta)-3^2\)
we then see that if we let:
then we will have:
\(\displaystyle (4u)^2-3^2=(3\sec(\theta))^2-3^2=3^2\sec^2(\theta)-3^2=3^2\tan^2(\theta)=(3\tan(\theta))^2\)
Now we have transformed this expression into a square, and since it is under a square root, we can get rid of the radical.
Mark already did in one of your http://www.mathhelpboards.com/f10/integration-involving-trigonometric-substitutions-5545/.
and given that:
then we will have:
now it's clear! thanks! this is the explanation I'm waiting for.
FAQ: Integration involving substitutions II
What is the purpose of using substitution in integration?
Substitution is used in integration to simplify the integrand and make it easier to integrate. It involves replacing a variable with a new one to transform the integral into a more manageable form.
How do you choose the appropriate substitution for integration?
In general, the substitution chosen should allow for simplification of the integrand. This can be achieved by looking for patterns, such as trigonometric functions or polynomial expressions, and selecting a substitution that will eliminate or reduce their complexity.
What is the difference between u-substitution and trigonometric substitution?
The main difference between u-substitution and trigonometric substitution is the type of variable being substituted. In u-substitution, a new variable u is introduced to replace a different variable in the integrand. In trigonometric substitution, a trigonometric function is used to replace a variable in the integrand.
Are there any specific rules for choosing the substitution variable?
There are no specific rules for choosing the substitution variable, but it is important to select a variable that will simplify the integral. Some common choices include the variable in the denominator, the variable in the exponent, or a variable that is being raised to a power.
What are some common mistakes to avoid when using substitution for integration?
One common mistake is forgetting to include the derivative of the substitution variable when solving the integral. It is also important to check the bounds of integration and adjust them if necessary. Additionally, be cautious of making incorrect substitutions that do not simplify the integral.
