Integration involving substitutions
  • MHB
  • Thread starter paulmdrdo1
  • Tags
    Integration
In summary, In the first problem, rewrite the integrand as \int\frac{2dx}{(1+x)\sqrt{x}}} and in the second problem, use substitution to get \int\frac{du}{(1+u^2)u}.
paulmdrdo1
385
Please help me with these problems:
1. \begin{align*}\displaystyle \int\frac{dx}{(1+x){\sqrt{x}}}\end{align*}
2. \begin{align*}\displaystyle \int\frac{ds}{\sqrt{2s-s^2}}\end{align*}
Re: Integration Inverse trig
paulmdrdo said:
please help me with these prob.
rewrite as
\(\displaystyle \int\frac{2dx}{(1+(\sqrt{x})^2){2\sqrt{x}}}\)
complete the square .
\begin{align*}\displaystyle \int\frac{dx}{\sqrt{2s-s^2}} = \int\frac{ds}{\sqrt{-[(s^2-2s +1)-1]}} \\ = \int\frac{ds}{\sqrt{-[(s-1)^2-1]}} \\ = \int\frac{ds}{\sqrt{1-(s-1)^2}}\\ let \,u = s-1\\ a=1 \\\ = sin^{-1}\, (s-1) +C \end{align*}
is my answer correct? did i use correct algebra in completing the square?
i still don't know how did you get 2 to be in the numerator and denominator of prob one.please explain. thanks!
Ignore the 2's and the extra [tex]\sqrt{x}[/tex] in the denominator and think strategically for a moment. Look at the rest of the denominator...The [tex](1 + (\sqrt{x})^2)[/tex]. What substitution do you think you are likely to use? Then make the substitution and solve for du. What terms arise?
-Dan
\begin{align*}\displaystyle let\, u = x^{\frac{1}{2}}\\ du = \frac{1}{2}x^{-\frac{1}{2}}dx \\ dx = 2\sqrt{x}\\... my\,\, answer\,\, would\,\, be\, = 2tan^{-1}\,\sqrt{x}+C\end{align*}
but i still don't get the new form of the integrand. where the 2 came from and
\begin{align*}\displaystyle(\sqrt{x})^2 \end{align*} in the denominator.
paulmdrdo said:
\(\displaystyle u = x^{\frac{1}{2}}\)
\(\displaystyle du = \frac{1}{2}x^{-\frac{1}{2}}dx\)
Look at the du equation. We need a 2 in the denominator to make a du. If we need one in the bottom, then we also need one in the top.
Perhaps the better idea right now is, now that you know the substitution you want, plug your u and du into the original integral and see what happens.
-Dan
Do you understand how substitution works? You need to see if there is an "inner" function and if this inner function's derivative is a factor in your integrand. Surely you can see that \(\displaystyle \displaystyle \begin{align*} x = \left( \sqrt{x} \right) ^2 \end{align*}\). Why did we choose to do that? Because if you know your derivatives, you will know that \(\displaystyle \displaystyle \begin{align*} \frac{d}{dx} \left( \sqrt{x} \right) = \frac{1}{2\sqrt{x}} \end{align*}\). Notice that you ALREADY have \(\displaystyle \displaystyle \begin{align*} \frac{1}{\sqrt{x}} \end{align*}\) in your denominator, which means that if you can turn it into \(\displaystyle \displaystyle \begin{align*} \frac{1}{2\sqrt{x}} \end{align*}\), then a substitution of the form \(\displaystyle \displaystyle \begin{align*} u = \sqrt{x} \end{align*}\) is appropriate.
Hello, paulmdrdo!
You can avoid that hassle . . .
[tex]1.\;\int\frac{dx}{(1+x)\sqrt{x}}[/tex]
Let [tex]u \,=\,\sqrt{x} \quad\Rightarrow\quad x \,=\,u^2 \quad\Rightarrow\quad dx \,=\,2u\,du[/tex]
Substitute: .[tex]\int \frac{2u\,du}{(1+u^2)u} \;=\;2\int\frac{du}{1+u^2} \;=\;2\arctan u + C [/tex]Back-substitute: .[tex]2\arctan(\sqrt{x}) + C[/tex]
FAQ: Integration involving substitutions
What is integration involving substitutions?
Integration involving substitutions is a method used in calculus to solve integrals that involve a variable substitution. It involves replacing the variable in the integral with another variable or expression in order to simplify the integrand and make it easier to solve.
When should I use integration involving substitutions?
Integration involving substitutions is useful when the integrand contains a complicated expression or when the integral is in a form that is difficult to solve using other methods, such as integration by parts or partial fractions.
How do I choose the substitution variable?
The substitution variable should be chosen based on the form of the integral. Typically, the variable chosen should be equal to a part of the integrand, such as a term or expression within a larger expression.
What are some common substitution techniques?
Some common substitution techniques include u-substitution, trigonometric substitution, and hyperbolic substitution. These techniques involve replacing the variable with a specific function or trigonometric expression in order to simplify the integral.
Are there any common mistakes to avoid when using integration involving substitutions?
Yes, some common mistakes to avoid include forgetting to substitute the differential term, failing to simplify the integral after the substitution, and choosing an incorrect substitution variable. It is important to carefully follow the steps and check your work for errors.
