Jndue
- 3
1234
Jndue said:Homework Statement
find
[itex]\int3+2\sqrt{1-\frac{x^{2}}{9}} dx[/itex]
Have tried multiple methods but none seem to work for me!
Jndue said:so...y=3+2*sqrt(1-(x^2/9))
then... y=y=3+2*sqrt(1-(sin^2(s)/3)) yes?
after that what should occur?
The formula for integrating a square root is ∫√x dx = (2/3)x^(3/2) + C, where C is the constant of integration.
Yes, the square root can be integrated using u-substitution. The substitution u = x^(1/2) can be used to simplify the integration.
To integrate a square root with a constant in front, first factor out the constant and then use the formula ∫af(x) dx = a ∫f(x) dx, where a is the constant.
There is no specific rule for integrating the square root of a polynomial. It depends on the specific polynomial and may require u-substitution or other integration techniques.
No, the square root of a negative number cannot be integrated as it would result in an imaginary number. Integration is only applicable for real numbers.
