Integration of abs(k)e^(ikx)dk
  • Thread starter Thread starter rmiller70015
    Integration
rmiller70015
This is for a quantum free particle problem, doing the Fourrier transform and I just want to make sure I've got the integral correct.
$$\frac{1}{\sqrt{2\pi}}\int^{\infty}_{-\infty} \phi (k) e^{ikx}dk$$
Where ##\phi## is:
f\left(k\right) = \left\{
\begin{array}{lr}
A(a-|k|) & : |k| \le a\\
0 & : |k| > a
\end{array}
\right.\\
Split the integral
$$\frac{Aa}{\sqrt{2\pi}}\int^{\infty}_{-\infty}e^{ikx}dk - \frac{A}{\sqrt{2\pi}}\int^{\infty}_{-\infty}|k|e^{ikx}dk$$
Apply the boundary conditions, this is where my biggest source of uncertainty comes from I doubled the integral and integrated from 0 to a instead of from -a to +a to get rid of that absolute value. I plotted the |k|e^k function and it appears to have even parity.
$$\frac{Aa}{\sqrt{2\pi}}\int^{a}_{-a}e^{ikx}dk - \frac{2A}{\sqrt{2\pi}}\int^{a}_{0}|k|e^{ikx}dk$$
$$\frac{Aa}{\sqrt{2\pi}ix}(e^{iax} - e^{-iax}) + \frac{2Ai}{\sqrt{2\pi}x}[ke^{ikx}-\frac{1}{ix}e^{ikx}]^a_0$$
$$\frac{Aa}{\sqrt{2\pi}ix}(e^{iax} - e^{-iax}) - \frac{2A}{\sqrt{2\pi}ix}(ae^{iax}-0 - \frac{1}{ix}(e^{iax}-1))$$
$$\frac{Aa}{\sqrt{2\pi}ix}(e^{iax}-e^{-iax}-2e^{iax}) - \frac{2A}{\sqrt{2\pi}(ix)^2}(e^{iax}-1)$$
Clean up and use Euler
$$\frac{2iAa}{\sqrt{2\pi}x}cos(ax) + \frac{2A}{\sqrt{2\pi}x^2}(e^{iax}-1)$$
Hi,
If you have to split anyway, why not write ##\phi = a+k ## from -a to 0 and ##\phi = a-k ## from 0 to a ?
Are you somewhat familiar with the FT ? Since your ##\phi## is a convolution of a boxcar in time (6) with itself, I would expect (14) something like a ##\displaystyle {\ {sin^2 x\over x^2}}\ ## for ##\psi ##.
Mathematica yields a simpler result (this one's wrong):
$$\frac{2A}{\sqrt{2\pi}} \frac{1-e^{iax}+iax}{x^2}.$$ On the other hand, if I evaluate the integral using the InverseFourierTransform function, I get a result like @BvU's expectation.
You can't double the integral from 0 to ##a## because while ##f(k)## is even, the integrand as a whole isn't.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
