Integration of an exponential function
Safinaz
Hello ,
How to integrate
## \int ~ dy ~ e^{-2 \alpha(y)} ##
My trial :
I think ## \int ~ dy ~ e^{-2 \alpha(y)} ## dose not simply equal: ## - \frac{1}{2}e^{-2 \alpha(y)} ## cause ##\alpha## is a function in ##y ##.
So any help about the right answer is appreciated!
What is ##\alpha(y)## ?
Should I assume it to make the integration, right?
Well, in this case let's assume it increases with y exponentially or it's a slowly varying function
You need to specify the function ##\alpha(y)## - i.e. give the actual formula for ##\alpha## in terms of y. Or (if integrating numerically) you need a table giving values of ##\alpha## for values of y over the range of interest.
If ##\alpha(y)## can be represented as a linear function of y (##\alpha(y) = ay + b## with a and b as constants) then the integration is clearly simple.
For more complicated functions, I believe there are no general analytical methods, though special cases may have solutions . E.g. with ##\alpha(y) = y^2## the integral can be expressed in terms of the error function – see https://www.wolframalpha.com/input/?i=e^(-2y^2)
Also, see discussion here: https://math.stackexchange.com/questions/19390/integrating-efx
Likes Omega0, docnet, Safinaz and 2 others
@Steve4Physics. Hay! just saying thank you very much! The answer is so helpful 😊
Likes Delta2 and Steve4Physics
