What Does Integrating a Complex Function Yield?
In summary, integrating a complex function yields a net signed area between the function and the x axis. Line integrals can be generalized for functions with codomain \mathbb{C}, which are studied in complex analysis. For functions with codomain \mathbb{R}, line integrals have a geometric interpretation involving a surface in \mathbb{R}^3. The contour integral in complex analysis has practical applications in finding complex derivatives, proving differentiability, calculating real integrals, and proving the fundamental theorem of algebra. However, there is no direct relationship to area or volume in higher dimensions.
pierce15
315
This is also a question for $$\mathbb{R}^2\to\mathbb{R}^2$$ If you have a complex function, $$f(z)$$ which thus maps from $$\mathbb{C}\to\mathbb{C}$$ what exactly does
[tex]\int_{a}^{b} f(z)\space dz[/tex] mean?
Integrating a function f(x) from $$\mathbb{R}\to\mathbb{R}$$ yields the net signed area between f(x) and the x axis. What would integrating a complex function give you? Also, can someone please explain what a path integral is? I asked my math teacher about this and he told me that it has to do with path integrals, but he hasn't studied complex analysis for years.
P.S. how can I type an equation that doesn't start a new paragraph and stays in my sentence?
If you have a function [itex]f:\mathbb{R}\rightarrow \mathbb{C}[/itex], then you usually define
[tex]\int_a^b f(x)dx= \int_a^b Re(f(x)) dx + i \int_a^b Im(f(x))dx[/tex]
You can generalize this kind of integral to line integrals.
In that case, we are given a curve [itex]c:[a,b]\rightarrow \mathbb{C}[/itex] and we have a function [itex]F:\mathbb{C}\rightarrow \mathbb{C}[/itex]. We define
[tex]\int_c F(\zeta)d\zeta = \int_a^b F(c(x)) c^\prime(x) dx.[/tex]
These are the integrals which are studied in complex analysis.
Functions [itex]f:\mathbb{R}\rightarrow \mathbb{R}[/itex] have easy interpretations for integrals: they are just the (signed) area under the curve. Although there are other interpretations as well.
Line integrals don't really have such easy interpretations, but they certainly are useful.
An interpretation that might be useful is if your function F has codomain [itex]\mathbb{R}[/itex]. So we are given a curve [itex]c:[a,b]\rightarrow \mathbb{R}^2[/itex] and [itex]F:\mathbb{R}^2\rightarrow \mathbb{R}[/itex]. We can define line integrals in this case by
[tex]\int_c F = \int_a^b F(c(t)) |c^\prime(t)|dt[/tex]
This looks a lot like the complex integral above (except for the norm). This can be given a geometric intepretation.
Indeed, we can see [itex]F:\mathbb{R}^2\rightarrow \mathbb{R}[/itex] as a surface in [itex]\mathbb{R}^3[/itex]. The curve c then defines a curve on the surface by [itex]t\rightarrow F(c(t))[/itex]. The area under this curve is then exactly the line integral.
See this nice animation on wikipedia:
That's a beautiful explanation, micromass. I wished I'd had that when I studied line integrals, together with the Wikipedia animation. (What we got was usually only a comment like "Just get on with your work and don't bother with 'understanding' what you're doing.")
piercebeatz: if you want to include TeX code "inline", you can enclose it in [ itex]...[/itex] tags, rather than [ tex]...[/tex] for paragraphs of code (without those spaces though).
[PLAIN]http://upload.wikimedia.org/wikipedia/commons/4/42/Line_integral_of_scalar_field.gif[/QUOTE]
Thanks, all that makes sense. But if you are integrating from [itex]\mathbb{C}\to\mathbb{C}[/itex], or [itex]\mathbb{R}^2\to\mathbb{R}^2[/itex] what exactly does integration give you? I see that for [itex]\mathbb{R}^2\to\mathbb{R}[/itex] or vice versa, you are working in 3 dimensions and you still get an area. What would you get if you did the same thing in 4 dimensions? For example, what would: $$\int_{1+i}^{2-3i} z^2+2iz+3-5i \space dz$$ give me? (I mean in terms of area/volume, not the actual answer)
There is no relationship to area or volume. At least: not that I know of.
OK. Are there any practical uses of definite integrals in a complex hypersurface?
Sure. Contour integrals in complex analysis are very useful.
Here are some applications:
  • Finding out which function [itex]F:\mathbb{C}\rightarrow \mathbb{C}[/itex] are the complex derivative of another function.
  • Proving that any complex differentiable function is in fact infinitely many times differentiable.
  • Calculating real integrals which are otherwise very hard to calcuate.
  • Proving the fundamental theorem of the algebra.
I know that only (3) would be interesting to a physicist, and maybe (1) as well. But if you want to know physical applications or interpretations of the contour integral, then I'm not the person for that (since I know no physics).
I like to see the subject of complex analysis as having two applications (at least that you can learn about fairly early on, there's more, but then I'd have to charge you (JK, I don't know more, it's above my paygrade)).
One is, it helps to do some difficult one-d integrals, the subject of contour integrals is a technique to solve 1-d integrals, by calling upon the complex plane.
The second application, is to 2-d slices of physical problems, like electricity and magnetism, or fluid dynamics. This is not arbitrary, the physical problems have to be of a certain type, obeying (approximately?) certain partial differential equations.
Now, as far as an area or volume for integrating f(z)dz, you might think of these as vector fields, f(z)=(s(x,y),t(x,y)), and dz=(dx,dy). Then f(z)dz is a strange product, sort of like a cross product (I'll be embarassed if that's actually what it is).
Oops, micromass already said some of this, I'm just rambling, oh well.
Related to What Does Integrating a Complex Function Yield?
1. What is integration of complex functions?
Integration of complex functions is the process of finding a function that, when differentiated, gives a given complex function. It is essentially the reverse process of differentiation.
2. Why is integration of complex functions important?
Integration of complex functions is important in various areas of science and engineering, such as physics, engineering, and economics. It is used to solve problems involving rates of change, areas under curves, and optimization.
3. What are the different methods for integrating complex functions?
The most common methods for integrating complex functions include substitution, integration by parts, partial fractions, and trigonometric substitution. These methods allow for the integration of a wide range of complex functions.
4. Is integration of complex functions the same as integration of real functions?
No, integration of complex functions is not the same as integration of real functions. While both involve finding a function, the integration of complex functions deals with functions that have complex numbers as their inputs or outputs, while integration of real functions deals with real numbers.
5. What are some real-life applications of integration of complex functions?
Integration of complex functions has various real-life applications, such as in signal processing, electrical engineering, and fluid dynamics. It is also used to solve problems in economics, biology, and other fields that involve complex data and relationships.
  • Calculus
