Integration of inexact differentials in Thermodynamics
In summary, in thermodynamics, some equations use inexact differentials (denoted by ##\delta##) instead of ordinary differentials (denoted by ##d##) to indicate path-dependency. When performing operations with these differentials, such as integrals, special rules must be taken into account. For example, in the second law of thermodynamics, ##dS= \frac{\delta Q}{T}##, if temperature remains constant, it can be integrated as if ##\delta## were an ordinary differential. However, in the first law, ##dU=\delta Q + \delta W##, this operation would not be correct since Q and W are path-dependent while U only depends on the thermodynamic
Sokolov
In Thermodynamics, I have seen that some equations are expressed in terms of inexact differentials, ##\delta##, instead of ##d##. I understand that this concept is introduced to point out that these differential forms are path-dependent, although I am not clear how they can be handled.
So, are there any special rules to be taken into account when doing operations with them (such as integrals) or can they be handled just as ordinary differential forms?
For example, with respect to the second law of thermodynamics, ## dS= \frac{\delta Q}{T} ## , if ##T## remains constant, can it be integrated as if ##\delta## were an ordinary differential? And what about the first law, ##dU=\delta Q + \delta W ##? Would this operation be correct?
##\Delta U=\int dU= \int (\delta Q + \delta W)=\int \delta Q + \int \delta W= \Delta Q + \Delta W##
Science news on Phys.org
Q and W are path dependent whereas U depends only on the thermodynamic state. So the heat flow and work done in going between two states that are even slightly (infinitesimally) different does not define a precise value for δQ or δW. However if you define the path and express Q and W in terms of state functions of the system, then you can denote them as exact differentials eg:
  • ##dQ_{rev} = TdS## or
  • dQ = dU + PdV where dW = PdV or
  • dQ = dU where volume is constant or
  • dW = dU where the process is adiabatic.
AM
Likes Lnewqban
Related to Integration of inexact differentials in Thermodynamics
1. What is an inexact differential in Thermodynamics?
An inexact differential in Thermodynamics refers to a differential that is not exact, meaning it is not a total derivative of a function. In other words, the path taken to reach a certain state affects the value of the differential. This is different from an exact differential, where the value is only dependent on the initial and final states.
2. Why is it important to integrate inexact differentials in Thermodynamics?
Integrating inexact differentials is important in Thermodynamics because it allows us to calculate the total change in a system, taking into account the path taken to reach that change. This is crucial in understanding the behavior of thermodynamic systems and making accurate predictions.
3. How do you integrate inexact differentials in Thermodynamics?
The process of integrating inexact differentials in Thermodynamics involves finding a suitable integrating factor, which is a function that when multiplied by the inexact differential, makes it exact. This allows us to use standard integration techniques to find the total change in the system.
4. What are some common inexact differentials in Thermodynamics?
Some common inexact differentials in Thermodynamics include heat (Q), work (W), and internal energy (U). These differentials are inexact because their values are dependent on the path taken to reach a certain state, rather than just the initial and final states.
5. Can you give an example of integrating an inexact differential in Thermodynamics?
One example of integrating an inexact differential in Thermodynamics is calculating the change in internal energy (ΔU) of a gas during an isothermal process. The inexact differential for internal energy is dU = nCvdT, where n is the number of moles and Cv is the heat capacity at constant volume. By finding the integrating factor and integrating with respect to temperature, we can calculate the total change in internal energy for the gas.
  • Thermodynamics
