Integration of Legendre Polynomials with different arguments
In summary: P_{l}(\cos{\gamma}) d\theta' d\phi' = \int_{\Omega} P_{1}(\cos{\theta'}) \left(P_{1}(\cos{\theta'}) \cos{\theta} + P_{0}(\cos{\theta'})\sin{\theta}\,\cos({\phi' -\phi})\right) d\theta' d\phi' $$Using the orthogonality property of Legendre polynomials, we can simplify this expression to:$$ \int_{\Omega} P_{1}(\cos{\theta'}) P_{l}(\cos{\gamma}) d\theta' d\phi' = \int_{
Alan Sammarone
Hi everybody,
I'm trying to calculate this:
$$\sum_{l=0}^{\infty} \int_{\Omega} d\theta' d\phi' \cos{\theta'} \sin{\theta'} P_l (\cos{\gamma})$$
where ##P_{l}## are the Legendre polynomials, ##\Omega## is the surface of a sphere of radius ##R##, and
$$ \cos{\gamma} = \cos{\theta'} \cos{\theta} + \sin{\theta'}\sin{\theta}\,\cos({\phi' -\phi}) $$
I am told that only the ##l=1## term survives due to orthogonality of Legendre polynomials (of course ##\cos{\theta'} = P_{1}(\cos{\theta'}) ##), but I'm don't see why, since the Legendre polynomials have different arguments.
How can I show that this is true?
Your angle ##\gamma## is an angle from the direction defined by ##\theta## and ##\phi##. The spherical harmonics of a fixed ##\ell## form an irrep of the rotation group and so your ##P_\ell## will be rotated into a linear combination of the spherical harmonics ##Y_\ell^m##. The Legendre polynomial ##P_1(\cos\theta') = \cos\theta'## is directly proportional to ##Y_1^0(\theta',\phi')## and so your integral will project out this component of ##P_\ell(\cos\gamma)##.
Hi there! It looks like you are trying to calculate the sum of an infinite series and an integral involving Legendre polynomials. This can definitely be a tricky problem, so let me try to help you out.
First of all, it is important to understand the properties of Legendre polynomials. One of the most important properties is their orthogonality, which means that the integral of the product of two different Legendre polynomials over a range of values is equal to zero. In other words, if we have two different Legendre polynomials, say ##P_{l}## and ##P_{m}##, and we integrate their product over a range of values, the result will be zero unless ##l = m##. In that case, the result will be equal to some constant value.
Now, let's take a look at the expression you are trying to calculate. We have an infinite sum over different values of ##l##, and an integral over the surface of a sphere. The integrand contains a product of Legendre polynomials, one with argument ##\cos{\theta'}## and the other with argument ##\cos{\gamma}##. As you correctly pointed out, due to orthogonality, only the ##l=1## term will survive in this sum. This is because when we integrate the product of ##P_{1}## and ##P_{l}## over the range of values for ##\theta'## and ##\phi'##, the result will be zero unless ##l=1##.
To see this more clearly, let's use the expression for ##\cos{\gamma}## given in the problem. We can rewrite it as:
$$ \cos{\gamma} = \cos{\theta'} \cos{\theta} + \sin{\theta'}\sin{\theta}\,\cos({\phi' -\phi}) = P_{1}(\cos{\theta'}) \cos{\theta} + P_{0}(\cos{\theta'})\sin{\theta}\,\cos({\phi' -\phi}) $$
where ##P_{0}## is the Legendre polynomial with ##l=0##. Now, when we integrate the product of ##P_{1}## and ##P_{l}## over the range of values for ##\theta'## and ##\phi'##, we will get:
Related to Integration of Legendre Polynomials with different arguments
1. What are Legendre polynomials and how are they used in integration?
Legendre polynomials are a set of orthogonal polynomials that are commonly used in mathematics and physics. They are used in integration because they provide an efficient way to approximate complex functions and can be integrated easily using various techniques.
2. How do I integrate Legendre polynomials with different arguments?
The integration of Legendre polynomials with different arguments can be done using various methods such as the Gauss-Legendre quadrature, Simpson's rule, or the trapezoidal rule. These methods involve breaking down the integral into smaller parts and approximating each part using the Legendre polynomials.
3. Can Legendre polynomials with different arguments be integrated analytically?
Yes, Legendre polynomials with different arguments can be integrated analytically. However, the resulting integral may be complex and difficult to evaluate by hand. In such cases, numerical methods can be used to approximate the integral.
4. Are there any special cases when integrating Legendre polynomials with different arguments?
Yes, there are some special cases when integrating Legendre polynomials with different arguments. For example, when the argument is a constant, the integral becomes a simple multiplication by that constant. Other special cases may involve specific values of the argument that result in simpler integrals.
5. How accurate are the results obtained from integrating Legendre polynomials with different arguments?
The accuracy of the results obtained from integrating Legendre polynomials with different arguments depends on the method used and the number of terms used in the approximation. Generally, using more terms and a more accurate method will lead to more accurate results. However, it is important to note that the accuracy may also depend on the function being integrated, and some functions may be better approximated by Legendre polynomials than others.
  • Differential Equations
  • Topology and Analysis
